broken bolt
Originally Posted by
speed20
get a drill bit (a size smaller than the threaded part) and drill STRAIGHT into the threaded part as far as you can and then put the drill in reverse and back it out....ive done this on oil pump screws, not sure if it would work on an exhaust bolt but its worth a try!
No way, no how will this work! If the bolt is siezed so bad that it broke off, what makes you think that a drill bit will walk it right out?? If it was a left hand bit and it wasn't siezed, MAYBE, otherwise it won't happen. Centerpunch, drill with good bits in steps to the largest size possible and try a ez-out. Heat from a torch will help in addition to the above.
'86 ATC 350 X FOR SALE-- GONE!
'86 ATC 200 X PARTING OUT
'95 Banshee--The most feared ATV ever built
'95 KX 125
'98 Polaris 700 XCR
'65 Mustang!!
