Results 1 to 13 of 13
Thread: cold weather and warm weather with 2 strokes
    Watertown, New York 13601
    3,382
    with a 2 stroke when i gets colder out doors does make it run lean or does it make it run rich?
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    speed20 is offline Check my feedback before buying from me Arm chair racerJust too addicted
    Jun 2002
    OH-IO
    816
    I believe the cold makes them run rich.....my dirtbike ran fine in the 65 degree weather, but in the 30-40 degree weather it loads up and doesnt want to run at all.
    Eastern Long Island
    1,688
    Cold makes 2 strokes or any engines for that matter run lean because the cold air is more dense.
    Lots O Trikes!!!!!
    3,382
    ok, now who is right?
    2006 YFZ 450
    Nov 2001
    B.C.
    933
    200xman has it right
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    temprature has alot less affect on jetting than humidity and air density ,,and most won't affect jetting very much ,,unless you are on the edge of rich or lean then you will notice the change,,,,,, on a cold damp morning my stock 86 runs a little on the fat side (rich) but cleans up in the afternoon if i jetted it down one size it wouldn't change as much cause it would be closer to the middle of rich/lean , in the spring and summer months there is almost no noticable difference ,, its a delicate balance and i choose to stay on the the fat side,,,,
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Well, you are all about right. The cold air is more dense, and since your jetting is fixed, you could be running lean in the cold weather, but the cold can also make your bike run rich, if you are riding at a good pace, you are getting colder air on your radiators, which may be overcooling the bike, thus making it rich. On air cooled engines, I dont mess around anymore, I make sure my jetting is perfect, pretty easy to blow them up, as opposed to liquid cooled bikes. So I say get a dial a jet, or make sure your bikes jetting is spot on for the weather, but it is better to run rich, than it is to run lean.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Rittman, Ohio
    6,276
    Both are right.
    Cold engines run much richer, but cold air is much denser. As a result, your bike will run extermely rich, until it warns up to operating temp, and then it will run leaner.
    Ive never changed carburetion for winter. They dont run MX in winter here which is the only time Im runningflat out screaming for extended periods of time anyways. Even when running lean you generally dont melt pistons at midrange, or trail riding, so Im not concerned even when doing harescrambles. If you like to get in the snow, spin the wheels, and make the engine scream for extended periods of time, it may be a different matter. If you keep in mind your running a little lean and keep your extended wheelspins at lower RPMs, your not likely to have a problem.
    3,382
    how long does a spark plug last you? it seems like i go through alot of them. I had my main jet changed from a 470 to a 360.
    2006 YFZ 450
    Jun 2002
    OH-IO
    816
    the plug in my RM250 has been in it for 2 years (from what the previous owner said) and he said its never fouled on him.
    Dec 2003
    62
    my friend had a 125 2 stroke in winter it would never run but in summer it werked great.
    Dec 2003
    80
    how is your friend
    who is your friend, surely it aint doody... cuz his 125 worked just great in winter as well as summer, just that his trike was a POS, and it always broke, cuz of what he'd do on her
    1982 YTM 200 chain (102kph)(sold)
    1986 YTM200 ER (91kph)(oil pump gone i think, sellin' her for $500)
    1989 YFM 350 Big Bear (70kph) currently in use)
    2004 660R Raptor.. Got Her!!!
    1996 touring LE ( 140 kph) putup till' next winter
    YAMAHA-- NO COMPETITION!
    Dec 2003
    62
    no johnny had one matthew
