1986 honda 350x put a new top end in it and now it wont move??????????????????
Rode this thing before tear down ran and shifted great tore it down put new cylinder piston rings put it all back togther now it will not shift its like the clutch is held in let off clutch it just sits there
Thanks for the update...sounds like you didn't put it back together correctly.
Did you do the clutch adjustment? Freeplay in the clutch lever should be 10-20mm. Not sure what else would cause that. Mabey if you are patient one of the senior members can really help you out.
Check clutch cable routing too. Good luck.
//ArrowChat Integreation Code
