Results 1 to 8 of 8
Thread: interchangable heads?
    Mar 2012
    scotland
    29
    hey people i was workin on my 200s engine and found out the heads no use.now will a 200x head fit or even a 185 head bolt straight on and work fine withouth mods or anything?jst asking to see if anyone has done or tried this.any help would be greatlt appreciated.
    Fl-
    64
    well any ATC 185/200 head will work, as well as the Xr200 head
    Mar 2012
    scotland
    29
    cheers for that so does that mean the xr200 and the 200x head are the same also
    PA
    3,515
    Back in the late 80s I used a 200s head on my 85 200x so yes they will fit.
    WWW.HREATV.COM
    Fl-
    64
    yep the top ends from all the 185/200 cc motors are swap-able from a 1980 185 to a 1985 200x! (and everything in between)
    and then the XR200 top end as well
    and also some Chinese knock offs as well ive seen
    NOTE: 86/87 200X is NOT the same!
    Sep 2007
    California, USA about 50 miles north of sacremento
    976
    I thought I read in a thread you can swap in the 200x cam or the xr200 cam for higher performance. Might be smoking crack though.
    Pennsylvania
    49
    Just went through the XR200 cam swap on my 200x and I bent a valve. The valve relief cuts aren't deep enough so I had the piston recut and now I'm waiting for my XR200 head. Kinda a frankenmotor XL185S bottom end, 200x cylinder and piston and XR200 cam and head. haha
    Feb 2003
    Australia
    927
    The bent valve should not have happened. Valve timing was probably out.
