Results 1 to 7 of 7
Thread: anybody fix 2 stroke pipes
    poohbee1's Avatar
    poohbee1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2010
    terre haute indiana
    404
    smashed a ct pipe right on the weld does anybody fix them . I have another but i was trying to save that one.Click image for larger version.
    Jul 2006
    western ny
    3,366
    it can be welded up using a mig and stainless wire. (assuming its a stainless pipe)
    GIT IT RAAAGGGGG !!!!
    Southern MN
    1,875
    That dosent look bad at all. I would consider that a ding. Some guys have had luck with spot welding a rod on there, and using a slide to remove the dent.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    poohbee1's Avatar
    Apr 2010
    terre haute indiana
    404
    I think I will take it off and put the other one on. I have a friend at a body shop I will see if he can do anything with it. still works great.
    Dec 2011
    Grand Rapids, MI.
    679
    There is another method that involves plugging one end of the pipe and attaching an air hose to the other. Then you set it to a high enough psi to get some pressure built up and use a torch of some kind to heat the spot where the dent is. With any luck it should pop out, for more detailed info I'm sure you could find a video on youtube.
    1986 KLT 185
    1984 200S
    NEPA
    7,051
    That will DEF pop with the air method.. VERY nice bike man,,very nice!!!!!!!!!
    poohbee1's Avatar
    Apr 2010
    terre haute indiana
    404
    the air method looks kind of scary .thanks 007 finally got a complete short track kit now all I need is some aftermarket shrouds that fit so i can take mine off and put them away with the red tank.
