Results 1 to 15 of 24
Thread: 1985 200x not kicking
    Feb 2013
    Walford, Iowa
    120
    I have a 1985 Honda 200x three wheeler and it refuses to kick over. I got it out when it was cold and rode it up to our house. I shut it off and then realized that it needed some fuel. So I went to kick start it and it wouldn't kick all of the way down. The kick lever would go a couple inches and then just stop and not go anymore down. Almost like it was binding up on something. When I was first kicking starting it it was making some weird sounds but since it started I didnt worry about it and now it wont kick over at all.
    Slidell, LA
    4,738
    could be a multitude of things....crank bearings, timing chain busted or pinched, rings busted or caught somewhere.....time for a tear-down
    Feb 2013
    Walford, Iowa
    120
    Yeah I figured it was something in the lower end. So im just waiting for a manual to come in the mail and then Ill tear into it. Should I be getting a gasket kit also, since Ive never torn a lower end apart
    There are free manuals available on here.
    Feb 2013
    chicago il
    505
    for what the kickstarter does move, does the engine turn at all. if it doesnt turn i would pill a side cover and see if you can spin crank by hand. it will help you decide if kickstarter or engine is problem. check out kbonly profile for service manuals
    Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
    Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
    Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
    KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
    Feb 2013
    Walford, Iowa
    120
    Ok thanks a bunch hopefully I will get to tearing in to in this weekend. And I know there are manuals on here its just that we have two other atcs that the manual would work for.
    Feb 2013
    Walford, Iowa
    120
    I took the case off and turned the crankshaft by hand. It would turn and I could hear the valves moving but it would only go about half a turn and then stop. I couldnt get it to go any further by hand.
    Slidell, LA
    4,738
    Sounds like your bearings are ghandi.
    Feb 2013
    west michigan
    10
    sounds like the same problem im having with my 200x.yaegerb knows these 200x's well so im going with his call on this one.looks like splitting the case time it will be my first time getting that deep into a motor and its kinda scaring me. good luck with it and please post updates
    May 2007
    Orange County, NY !
    1,673
    take it out of gear and turn the e-brake off.
    Just kidding, check the bolt that holds the kick start ratchet in place.
    Feb 2013
    Walford, Iowa
    120
    Yeah its my first time splitting the case to. I might just end up taking it somewhere just to be sure that it gets done right. But that might be to expensive. And do you have to take the entire head off to split the case.
    Feb 2013
    Walford, Iowa
    120
    what do you all have to take off, like the flywheel, clutch, etc.
    Feb 2013
    west michigan
    10
    i looked in the manual it says crankcase must be seperated. before sperating remove head , clyinder and piston,clutch and gearshift linkage ,altenator. im gonna start at the top and hope i get lucky.maybe something is hung up or pinched.if it is a bad crank bearing i might have to rethink my project. best of luck with yours.if you do tear into it yourself can you post some updates and pictures?
    Feb 2013
    Walford, Iowa
    120
    yeah i will and I tried to tear in it to day and I was trying to take the valve cover and head off. But I could not get the valve cover off, it wouldn't even budge. So I have to somehow get that off. But I dont want to pry on it since its such a soft metal.
    Slidell, LA
    4,738
    Quote Originally Posted by Evan Hagenow View Post
    The rocker box cover can be a pain. Especially if its never been tore into. DO NOT use a screwdriver to pry it apart from the head. Loosen and remove the four allen heads and the acorn nuts and then take a rubber mallet and lightly tap around the rocker box cap. It will take some patience, but eventually it will come off. Remember, do not pry anywhere on the box or any other part of the engine for that matter.
