had same problem with a 250 sx front end. had to beat the tar out of it but eventually got it. brass
is nice but i needed big sledge and put it in a vise. just do not strike directly with steel
it will mushroom the threads or just ruin them. use a wood block between
and axle.
i like the idea of trying a shop press, i didnt have access to one at the time. just be careful with the setup because the brake cover brakes easy, maybe try leaving all on rim and put in press. just be careful how much pressure you use i have steel and aluminum practically expload in shop press' when people are careless. again use a wood block between press and axle threads.
good luck
Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
