Results 1 to 12 of 12
Thread: EXTENDED axles... worth the money
    Sep 2011
    New Castle, PA
    1,134
    Question EXTENDED axles... worth the money
    hi, i have someone in my neighborhood selling a +6 inch extended axle that would fit my 83 200x, just wondering if this is a good upgrade, because normally people go with a extended axle with an extended swinger or just a axle that is +2 or +3 in. my X is all stock, so if i can get the axle for the right the right price, is it worth it? thanks in advance for any input
    -RG
    Gone:
    Blossvale NY
    4,563
    I have a DB Eliminator +4 and ITP's that are offset an inch more than OEM each making my R 6" wider than stock. And I wouldn't have it any other way. It's the way they SHOULD have made em!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Dec 2005
    Wisconsin
    1,141
    BUY IT, I'll buy it off you if you don't want it.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Sep 2011
    New Castle, PA
    1,134
    Quote Originally Posted by WIkid500 View Post
    how much should I be willing to pay? the guy buys and sells old dirt bike and atc stuff all of the time so i have no doubt that he knows what he has, but in his CL ad its just 'best offer'... and i dont know how much to offer him if i want to buy it...
    Gone:
    Slidell, LA
    4,738
    Quote Originally Posted by rg97 View Post
    Depends on the manufacturer. Do you know what it is?
    Gripit'n'ripit's Avatar
    Gripit'n'ripit is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    Rochester NY
    251
    Looking around, different names and qualities vary in price. Dura-blue for you're machine new is the $500 range. If it's on CL and used, offer less (obviously). Definately worth persuing.
    Or (if you're a shrewd and cheap SOB like myself) you can find wheel spacers, maybe hubs from another machine. I'm using TRX hubs on my 250R, they give me almost +1 on each side.
    81 250R Custom
    83 250R (in progress)
    98 Scrambler 400
    03 Bombardier Quest 500
    07 Polaris Predator (sold to klondike1020 )
    68 VW Dune Buggy
    N.E. Ohio
    2,005
    +6" is about as wide as you wanna go IMO. It's more of a trike to turn but getting over the bars more at low speed cures that. If you jump or ride hard, or are thinking of racing, it's the way to go. Spacers IMO move the flex point of the axle, placing the stress point out of it's targeted area. They work in FT and Oval racing just fine...but I wouldn't jump em'. Hardcore trail riding may see you catching the inside tire with a +6" but thats what your stockers for if it suits you better. Sliding the X with the extended axle is where that stablity shines in the +6". I ride extended axles exclusively and recomend them. If what he has is used...the condition is key. $125 tops New old stock $275-300 tops...post pics if you mount it.
    Rittman, Ohio
    6,276
    +6 on a 200X might be okay for FT, makes for a poor handling MX machine, is will take the best handling trail machine, and turn it into one of the worst. Friend got a great deal on one, ran it on the MX track and it sucked until I suggested he take the offset rims from his other bike and put them on it backwards to subtract a few inches.
    Marty is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2007
    Mesa, Az
    644
    They are worth every penny! Just dont buy a new one, if you can buy it used and take to a machine shop and have him or her check straightness.
    Sep 2011
    New Castle, PA
    1,134
    i would have posted a pic, but for some reason the seller removed them from his ad...
    but anyways, the axle he has (from what i could tell by the CL pics) was brand new, never used but there was no name or identifying mark that i could see. i might not get it anyways, because im on such a tight budget, spending so much $ on my 'shee (i know... its 4 wheels but always) i have at most $150 to 200 to spend on it, and my guess is that the guy wont go that low if it it a Dura blue. +6 just seems a little much, because the main place i would ride is in the tight woods on my property and (eventually) silver lake dunes. i can see it now... a wreck because i clipped a tree cause im too wide
    Gone:
    Yup, not good for MX or tight trail riding. Like you said, clip one tree and it's bent.
    Be nice to own though, it's not going to go down in value.
    Biggest thing, make sure the axle journals and sealing area are in spec or it is basically useless.
    Jun 2004
    Pyeongtaek, South Korea
    474
    If you don't buy the axle and want a little wider stance, just use 400EX/450R hubs. They fit the 200X's splines and move the wheels out 1" on each side. Genuine Honda parts, +2" overall, the ability to widen it more with wheel offset, and all without the trouble of swapping the axle. This is the plan for my 200Xs. Of course, if you don't buy it, pass the info on for our trike brethren.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
