Thread: 4 STROKE When do you need CAM CHAIN??
    Well noone wanted to buy the 85 250SX motor for 300$ so I figured why the hell sell it?? I'll spend that much in gears and one way clutches alone if I ever need any parts and decided to keep it. I plan on building a motor for the 87 250SX with a cam and a high compression piston. But I wondered, does a perfectly good running engine that has always had oil changes need a cam chain and gears - or hell for that matter what about main bearings?? - Four strokes just don't seem to eat up lower ends very much but if I'm gonna do it I might as well do it well.
    Will the chain have play in it like a bad drive chain?? Will the sprockets show rounding teeth?? The tensioner is self adjusting and not noisy so that doesn't indicate much for me.
    Any ideas there four stroke builders???????
    Nov 2002
    Kirkville, NY
    3,831
    As long as the cam chain has been keeped ajusted the chain and gears don't wear that fast. I would just keep it ajusted and when it starts making noise and can't be ajusted anymore then it is time to replace it. I have bought 2 trikes with bad cam chains and they both were the type that looked like no maintinance was ever done to them. I have never replaced the lower end bearings though. I have thought about it wondering if it would make it easier to pull start since it seems that some bikes are easier to pull start then others.
    -Andrew
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Yeah, check it like you do sprockets and chains, if they look like they are in good condition, just keep them.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Thing is I have a 3rd junk motor in my cellar that had a nasty cam chain noise and it had an aftermarket chain in like advertised in Dennis Kirk but I can't feel any slop in it and I know it was the noise as all head components were tight and score free and the valves were adjuxted fine too - that chain was very noisy yet I couldn't feel or see the play?
    The SX is self adjusting so you can't tighten it up - when it gets noisy and the adjuster is working fine thats when you junk the chain, sprockets and guides.
