Results 1 to 9 of 9
Thread: Removing rust from 350x head pipe, can it be done?
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    The 350x I am looking into getting has a rusted head pipe, would sandblasting take the rust off so that I can paint it, is is there another way (I just dont wanna buy a new head pipe, because I will probably buy a whole aftermarket system in the future).
    Current Rides-Soon to be 85 350X, 84 200X
    PastRides
    86 250SX 85 Tri-Z (yellow) 85 Tri-Z (silver) 86 200x 01 Blaster 99 Blaster 85 ATC250R 86 ATC250ES 84 Tri-Zinger 60 ATC500R Project
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    potsdam NY (upstate)
    1,437
    usualy on old headers that are rusted bad it isnt worth trying to repaint them because the paint will eather fall off or burn off in the end your better off wating and buying a whole new one when u do the rest of the exaust
    looking for a TRI-Z 250 to restore at the moment
    LONG LIVE THE 2 STROKES !!!
    roofinggun is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2003
    202
    rust
    When I got my X I took a dremel with a sanding drum and took off allthe rust and then painted it with high temp. It looked great---for an hour. Tom Batts posted a link in a topic reply a while back of a place that blasts them and paints them like new.
    jdparsons1's Avatar
    jdparsons1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    Toledo, OH
    360
    Good ol' trusty bench motor and a wire brush wheel. Takes pretty much all the rust off. Then prime and paint.
    Quote Originally Posted by jdparsons1
    Bench wire wheel works fine and a 4" grinder with a wire wheel on it works even better. To truly get all the divots - sandblasting works great and I have done a few 250SX headpipes and then used high heat paint and they look great. I don't have a closeup picture of my 250R pipe but it was looking real bad before I sandblasted it and now it looks super!!
    Indiana
    192
    as stated above, use a wire wheel or bench grinder to remove the rust and use a dremel with a wire wheel to get what you can't wi the grinder, then buy some some high temp paint, POR-20 or Black Velvet is the best i have found(a friend has had it on his car headers for 8 years and they haven't rusted or turned color yet), but it is a little expensive, $16 for a 1/2 pint, but thats enough for at least 2 pipes.
    Tim is the name
    85 350X(86 motor)
    83 200X(stripped down for a total rebuild)
    85 200S(project)
    Central PA
    1,952
    I just bought a 30 gallon craftsman air compressor, and a sandblaster attachment, I dont have any grinding tools yet, so I am going to sandblast it. Thanx for all the suggesstions though.
    PastRides
    SOON MY PRECIOUS!
    A Sandblaster will get the job done in only a few minutes.
    Quote Originally Posted by Tri-Z Pilot
    I have a brand new 35 gallon 6HP Craftsman and a 40lb pot pressure Blaster - It works SUPER - but only for about 45 seconds and then you are wasting sand. I truly have found that removing the bulk of junk with a 4" grinder and a wire wheel on it 1st that sandblasting works much better as you can just kiss te areas you already stripped.
    Anthow, thats what works for me and I have done numerous exhausts.
