Results 1 to 9 of 9
Thread: 1983 Honda ATC 110 *WON'T START*
    Nov 2010
    new brunswick
    10
    Angry 1983 Honda ATC 110 *WON'T START*
    bought this from a buddy real cheap. Replaced the piston and rings fixed a valve(bent abit) set the timing, also put a new gasket kit on it. The bike has spark and is getting fuel but still wont start. But everytime i pull it over gas sprays (resembles mist) into the airbox... Does anyone have any suggestions on what i could do to get it running or whats stopping it from running??
    Jan 2013
    MINNESOTA USA
    46
    Did you check Vale clearance?
    Nov 2010
    new brunswick
    10
    Quote Originally Posted by 218honda110 View Post
    Yes I did.
    MN
    3,263
    If its blowing the gas out then it sounds like timing, or the intake valve isnt closing.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Nov 2010
    new brunswick
    10
    Quote Originally Posted by kb0nly View Post
    I set the timing perfectly, so out of your two suggestions it's probably the valve..
    Feb 2013
    chicago il
    505
    which valve bent. sometimes when the valve bends it can mess up seat. if you have fuel coming back through carb and timing is right it sounds like valve seat is bad and when engine is coming up on tdc it is pushing air/fuel mix back through intake valve. pressure test it
    pull schrader valve (like in valve stem) out of a compression tester hose and thread into cylinder and hook up air from compressor. to do this you either have to pull cam or put breaker bar on crankshaft and hold it at top dead center (valves closed). listen for air coming from intake or exhaust.
    Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
    Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
    Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
    KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
    MN
    3,263
    Quote Originally Posted by duke972 View Post
    That would be my guess as well, valve or valve seat, you didn't mention which valve you replaced but if it was the intake i would do a compression test and look it over good. I only suggested the timing because its seems like thats always the problem when the top end has been taken apart, its not always apparent how to get it right the first time.
    Nov 2010
    new brunswick
    10
    Quote Originally Posted by trike savior View Post
    The intake valve was bent, a previous owner must of put a long spark plug in it. I'm going to try and get a new valve tomorrow from a friend and see how that works if it does ill post here with a start up video if not ill just post...
    Feb 2013
    chicago il
    505
    another valve wont help if you already replaced it with new one. we are talking about the valve seats in the cylinder head. should make tight seal. if you already took it apart, put head upside down in a vise (valves up) and pour gas in the combustion chamber until it is filled up above the valves. it should hold the fuel. if it leaks out, check intake and exaust ports for fuel to see which is leaking. if it leaks you need new head or take it to shop and have new valve seats cut.
