Results 16 to 30 of 31
Thread: TRI-Z likes Reed Spacer
    Mexico
    9,018
    Quote Originally Posted by christph View Post
    Reed spacers have been around for a long time and they sell them for most two stroke motorcycles and atvs. If they were complete and utter BS they wouldn't have been around for so long.
    Keep in mind that anyone with a mill, or laser can crank these out all day long for under $5 bucks each with zero liability issues, so it stands to reason there would be a lot more sellers out there than for say an aftermarket cylinder, or head.
    ktmcrasher is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2012
    cumbria england
    186
    sorry to hijack your thread a bit b but..
    could i use those part numbers for the vforce3 to determine what bikes they were intended for & then pick up vforce4 instead?
    Rittman, Ohio
    6,276
    When it comes to a TriZ, reed spacers are like turning a full circle to undo the damage to performance of your other "mods". When you eliminate the boost bottle, and put in an aftermarket reed block, and fiber reeds, and then add the reed spacer you are accomplishing the same thing as simply adding a set of Boysen reeds to the stock block, and keeping the stock boost bottle intact. They are shiney and pretty though which I guess justifies the expense.
    Arizona
    843
    As many of you know the stock manifold on the Z is very small. When I went with the 38mm carb I also went with Sprock's manifold and it doesn't accommodate the boost bottle, otherwise I would have left it on. Perhaps the reed spacer did undo the loss of the boost bottle. But for those skeptics, that would only support the general theory a larger volume intake (especially on this engine) improves engine performance, and that you can get it either through a boost bottle or reed spacer. The point I would make about a boost bottle, however, is that it is a dead end reservoir and quickly develops a vacuum on the upstroke, and therefore its contribution to the air-fuel mixture is limited (unlike the banshee where the pipe (stock) or bottle (aftermarket) connects to the other manifold and draws on it). A reed spacer doesn't have that limitation.
    Arizona
    843
    Oh, someone asked where I got the V-Force 3. I got it from Greg at Off-Road Innovations. He specializes in Tecate parts but also has stuff for the Z. That's where I get my Sprock parts. From what I understand, Sprock had Mototassinari run a batch of reeds for the Z. I think I got the last one. As others said above, however, there may be one for another machine that fits the Z.
    volfan537240 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Eufaula, AL
    292
    Reed spacers do nothing and boost bottles on banshees are the biggest waste of money on the planet. On another note, I have some snake oil for sale if you'd like t buy some....
    85 tri-z (in pieces)
    421 cub banshee
    Arizona
    843
    I find it amazing when people who don’t know anything about my machine try to tell me what worked and what didn’t. Unlike you, I am not making a blanket claim about reed spacers. I'm saying it improved the performance of my engine and I will believe my direct experience over your assertion.
    Eufaula, AL
    292
    Hmmm... I guess the engineers at yamaha could've made the intake super short and the reed spacer makes it about right bahahaha. Seems like it would be a common mod though, maybe like in the wrench report.
    421 cub banshee
    Gold Hill, OR
    1,295
    Quote Originally Posted by volfan537240 View Post
    Well they did put a boost bottle on it stock so that says something for their engineering lol.
    On a side note, years ago I ran a reed spacer on a mildly built Blasterd (piped, ported, 36mm Pj, etc) and it seemed to smooth the power delivery out and it ran better, IMO, than without it. Using the seat of the pants dyno, of course.
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    Eufaula, AL
    292
    I've been around banshees for a long time and reed spacers do nothing. I haven't been around tri-z's long so it MAY be different ( I seriously doubt it but I don't know everything).
    I know that the op was just trying to share info so I'm not trying to bash you but who knows? You could've sealed up a air leak at the intake when you put the spacer on and there's your power difference.
    421 cub banshee
    Quote Originally Posted by ezmoney1979:1199429
    I was thinking the same thing. My theory on the Z having a factory boost bottle is this- Boost bottles were all the rage back then and a lot of people bought them aftermarket and put them on their bikes. For the initial cost of the mold and probably 15¢ per bike's worth of plastic, Yamaha now had a "leg up" over the competition.
    Aug 2004
    Ab Canada
    4,368
    ill add my 2 cents here, seeing as everyone else has
    "boost" bottles where originally designed for piston port NON reed valve motors, simply to create a lower vac on the intake side and keep the Air/fuel from blowing back through the carb and out, now however on a Reed valve motor it dose much the same, but creates a higher lift of the reed petels for more flow at a varrying rpm, a reed spacer helps in that aspect, most modern 2 strokes have little "cups" under the reed valve area cast into the intake track to keep a constant flow and air moving, if you look at your old smokers 9 times out of 10 you will see small black deposits under your reed area from just that..no flow,
    1985 Tri-Z-
    Sep 2006
    Northwest Indiana
    1,893
    The yamaha energy induction intake design was a way for them to publicly announce performance. It was widely used on many
    IT and YZ models in the 80's. They designed it's placement, along with it's aggressive looking sticker to be seen. This was a very
    Good marketing idea with catchy style that provoked thoughts of performance. In reality, it did little in terms of performance. The
    Theory was the extra volume it created would smooth out intake pulses off idle when throttle was snapped open quickly. The Tri-z
    Had a very smooth torque oriented power. Much like any modern intake tube on many cars and trucks where remote air filters
    Are used, which the Tri-z had. It allows for a big gulp of stored air before the incoming air is up to speed.
    Sep 2006
    Northwest Indiana
    1,893
    Generally speaking, reed spacers, or torque plates add low to mid range power. This depends alot on the design of a particular engines intake
    And port layout. For example, the Early Tecates intake is huge. The reed block reaches in very close to the intake bridge
    Where it can fill the cylinder with alot of volume fast. Tri-z's had a poor design for high rpm power.The entire intake system
    From the carb to the ports was a failure in horsepower production. There are only a few people who truly know how to get big power out of them. Sadly we lost the king of Tri-z's. I do love the Tri-z however.
  15. #30
    Arizona
    843
    I was just thumbing through a 86 Dirtwheels I picked up on ebay. I love reading through the old articles and ads. I can't believe the prices. $250 bucks for a Westcoast swingarm. Anyway, I came across ads for hop-up kits for the Z and other machines and a lot of them included reed spacers. It seems like Mikuni flat side carbs were also big back in the day.
