take it easy barnett dont you remember when you were first starting out, didn't know much and got flustered when you had a problem you couldnt fix. hes just having trouble explaining what hes finding. you cant expect everyone who works on these to be die hard mechanics like us, for some people its just a toy and a hobby and they're just trying to save the money of taking it to a shop. this site is for them too
but woody you need to read our posts more carefully because barnett did explain this.
you need to go through your entire fuel system. get yourself a five gallon bucket from home depot, lowes whatever. remove your tank and cap and dump it into bucket upside down. this will cause the fuel to rush out hopefully taking dirt and debris with it. take a look and see whats in the fuel. if there is a lot of stuff floating around you need to clean tank. while its empty inspect inside of tank for rust. what i normally do to clean it (and some of you green, tree huggers might not like this) is fill it with water till its full, slosh it around and quickly dump it out the cap hole. plugging fuel line holes will help. again you are trying to get everything to comeout with it. do this a few times. if you found your tank is rusty inside (not bright shiny metal) i suggest buying a gallon of "metal rescue" (look it up online) and using it on tank. ewither way your final step after you are confident it is clean and you are done with the water and metal rescue and the tank is empty, pour in some gasoline (not much, maybe a few oz's) put the cap on and slosh it around until fuel has hit everywhere. the idea here is to absorb any water into the fuel. then dump the water/ fuel into that five gallon bucket. if you want to save the fuel that came out of the tank before you do this that is fine but use a funnel with a fine screen to get junk out.
now your tank is clean but i would still suggest some tiny fuel filters you can find on ebay for both lines
cleaning your carb is as simple as making sure everything is clean. buy a can of brakleen that has a straw taped on it. you will also need an air compressor and a little air shooter with a tip you can use to blow out all the ports. take pics with your phone or camera of the carb so you know how it goes back together.
especially after you remove bowl. remove everything till you have a bare carb body with noothing on it. every screw, jet, carb slide (part that moves with throttle cable). put the straw on your can of brakleen and hit every hole with the brakleen and then the compressed air, this will blow any junk out of carb.
let us know when you remove bowl from carb if you find a brass float or a plastic float. if you find a brass float we have more to talk about. you need to look at the needle which is connected to the float and sits in a hole. it allows fuel in from tank. the tip should look like a perfect ^ (cone) if there are any worn spots it needs to be replaced. same goes for idle mix screw. it is the only other adjustment screw on carb that is not the one that contacts the carb slide
reassemble the carb and post what you have found on here. then we will talk about properly adjusting the carb once you have it back on
Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
