what gearing are you guys running on your Z's?
Front and back?
Front and back?
SEND ME PM HERE - CLICK HERE
Dirtbikes:
1988 Yamaha DT
stock gearing on my 85 with 20" stock banshee tires, to short of gearing and in 5th gear real quick. dont like it. in the sand with a 20" paddle its not to bad for duning.
Team Blue: 85 Tri-z 250: under the knife
Team Red: 87 Trx250r 01Cr80 15 CBR600RR
Team Yellow: 06 Ltr450 11 Hayabusa
Yea with porting on mine 4th feels so low its just going nuts.
I am thinking a smaller counter to let it pull longer...
Dirtbikes:
1988 Yamaha DT
Is anyone running a 13 tooth?
Dirtbikes:
1988 Yamaha DT
I'm running a 13/42 on my Z with 20" tires and it is just about spot-on. I have an 86, however, so it is a 6 speed transmission--thankfully. My 86 Tecate is a 5 speed and it really needs 6. With too few gears it is hard to get the bottom and top you like. Either is it geared to too low and the top end suffers or it is geared too high and the bottom suffers.
I will try to run that combo. Sounds good.
Dirtbikes:
1988 Yamaha DT
