Thread: yamaha tri zinger gear oil ?
    fingerlakesny
    2,834
    what should i use and how much ? its blue so i think it's an 85...
    250r dust runner
    Nov 2011
    New york
    115
    300 ml. or .32 qt. of 10w-40 or 10w-30. Theres a sticker on the frame behind the front fender that will say the year (if its still there). If you need any other references there's a complete manual here http://www.oscarmayer.net/atc/manual...vicemanual.pdf
    Quads:
    2004 Ltz-400
    2012 Ltz-400
    Trikes:
    85 ATC 250r
    85 Tecate
    82 Tri-moto 125(The wheelie machine)
    85 ATC 70
    85 ATC 110
    84 Zinger
    Bikes:
    03 Rm 60
    Sleds:
    05 f5 Firecat
    78 Lynx 275
    fingerlakesny
    2,834
    ok, thanks alot guys...
    250r dust runner
    Quote Originally Posted by russ98atc View Post
    Quote Originally Posted by tecat-z View Post
    It's not hypoid gear oil, and it's not grease either. It comes in a tube and is availiable at the Yamahe dealer and is called Grizzlly grease. It's has a consistency like jelly. It's used in the cvt of the yamaha grizzly atv's, and others. The axle assembly has to be removed and cleaned in a pressure type solvent tank with ring and pinion exposed. Then squeeze contents into housing. It's the correct lubricant for the tri-zinger.
    OK, you can't both be right here ladies. Let's hash this one out, shall we?
    Nov 2011
    New york
    115
    [QUOTE=fabiodriven;1200583]OK, you can't both be right here ladies. Let's hash this one out, shall we?[/QUOTE
    tecate-z was referring to the grease for the rear axle housing
    Quads:
    2004 Ltz-400
    2012 Ltz-400
    Trikes:
    85 ATC 250r
    85 Tecate
    85 ATC 70
    85 ATC 110
    84 Zinger
    Bikes:
    03 Rm 60
    Sleds:
    05 f5 Firecat
    78 Lynx 275
    Ya I know now. We actually sorted that out in one of the OP's 7 other threads about Zingers.
