Results 1 to 3 of 3
Thread: More Power for a KLT 110
    Feb 2013
    Hello Everyone,
    I'm a new registrant as of yesterday. Have been checking out the forum for a while and decided I needed to sign up and get some info if I could. I was wandering what is available for my klt 110 for engine upgrades? Are there performance cams, stroker kits, or whatever? Looking to make that little motor run stronger that it already does. It is stock right now with a standard piston. Any other ideas would be greatly appreciated.
    Thanks Again
    Springfield Mo
    3,309
    shortline would be the one to ask. I know that there were cams, exhaust, etc for that model, but I do not know if they are still available.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Jan 2013
    minnesota
    5,911
    Hello
    Unfortunately unless you get some other info regarding current performance upgrades for the klt 110 I think those parts are no longer made. If you find this to be the case you can still have some of the parts made depending upon your budget. If money is no object then you can contact "vintage klemm" on the internet and he can build a stroker kit and supply a custom ground cam for you. If you are on a budget then you can get a cam custom ground for around $150.00 port the cylinder head, get a custom piston high compression piston made from wiseco or je pistons get a pipe made, install a slightly larger kehin or mikuni carb and maybe cut some metal off the flywheel to reduce weight.
