Results 1 to 12 of 12
Thread: What Could Be Burning The Plug ?? Atc 70
    junjun01 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    290
    It Was Running One Day At Idle The Shutt Off.,Check The Plug, It Was Black, Try To Clean It But Dind't Work;Got New Plug Bike Started Right Away...Ran Idle For Couple Minutes Then Shutt Off Againg !; Check The Plug And Its All Black Again ..It Looks Like Is Burn...What Can Be Causing This ??.............Any Takers ?
    Aug 2003
    290
    The Plug Smells Like Gas Too !...I Try To Clean Then But That Don't Do It...Its Like They Burn.....Please Help....More Snow Is On The Way Tonite !
    JMiller's Avatar
    JMiller is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    piston rings worn, :shock:
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    Aug 2003
    290
    Could That Burn A Plug??.....I Mean,Its Possible For The Plug To Burn ?
    I Does have Normal Comprssion...& No Engine Noises Or Smokes :?
    jakey is offline At The Back Of The Pack Arm chair racerFirst time rider
    sounds like timing is off, piston is not compressed when chamber combusts?
    85 200x(NICE, Looking to sale or trade for 2 stroke trike or dirtbike)
    Looking for DG, Supertrapp, or Basani exhaust. Will pay up to 100 dollars for good condition pipe.
    Black plug could be jetting id look at the carb first.
    1983 Honda 110
    1967 Mustang
    Rittman, Ohio
    6,276
    If you start a bike up cold, let it idle for a couple of minutes, and check the plug, in most cases it will normally be black and wet, 2 stroke or 4. They all run super rich while they are cold, and you cannot take any valid plug readings that way. All readings must be talken AFTER you reach full operating temp. Then you need a top end reading to setup the main, a half throttle reading to setup the needle/clip, and you setup the pilot air screw for best throttle response off of a stable idle, and its needs to be done in that order.
    Aug 2003
    290
    I'll Try All This But First I Must Get Another Plug; Like I Say Now I Have 3 NEW Dead Plugs...Only Works For About 5 Minutes,Then....Next Plug Please ! :evil:
    Dec 2003
    10
    burnt plugs
    trailprotrailpro atc 70 is either off her timing or she is flooding her head wit to much gas.
    82 honda atc 200(X2)(crappy bikes)
    85 yamaha 225 dr(bought in parts never werked)
    84 200 es big red
    85 250 es big red
    82 ytm 200ek(chain)
    76 motoski spirit 12hp
    85 250 trx(sold $450)
    81 XL 125s (current ride)
    Aug 2003
    290
    How Do i Stop All That Gas From Going In ?...I think U right In The money
    It Was Idling Bad & Leaking Form Over Filled Hose
    Shrewsbury, West Virginia
    564
    I don't think its the timing because a little 70 probably wouldn't idle if the timing was off. I think you're float is getting stuck open since the plug is black and gas is coming out the vent tube. If you're gonna open up the carb, go ahead and get a carb rebuild kit. Hope this helps
    Justin ~hondaATCman~
    '82 Honda ATC 110
    '81 Honda ATC 250r (Summer Project)
    '87 Suzuki LT 250r Quadracer - Very Modded...FAST!!
    '03 Yamaha Big Bear 400 4x4
    '85 Ford Bronco II 4x4 2.8 V6
    Dec 2003
    10
    the black plug
    yeah like i said befoer its most likely the carb or timing. Heres a old trick me and by friens use and its werks like a charmer. take trailprotrailpro carb off trailprotrailpro bike and take it apart, then boil it in vinegar. The vinegar will take all the dirt off the whole carb. This may sound stupid to u butit werks. o yeah do this outside on a camp stove or sumting and a old pot cuz it will make trailprotrailpro house smell. (learned from experience) then jus dry it with a hair dryer and put back on the bike, if it dont werk its either off timin or trailprotrailpro nedle and seat r gone, which also causes plugs to turn black.
    84 200 es big red
    85 250 es big red
    82 ytm 200ek(chain)
