SEND ME PM HERE - CLICK HERE
Dirtbikes:
1988 Yamaha DT
DG exhaust with heat shield, I originally thought it was stock, 83/4R
This is a nice sectional, muffler and pipe must be used together. Anyone have an idea what it is?
Looks like a Blaster![]()
Since when does a 3 wheeler with a kawi front fender, a sharp turning radius, and some aftermarket parts look like a blaster?![]()
Love it !!!!
Well have a current build happening so I have a good pile of parts!![]()
Here's a white bros swingarm I have for the first gen, It looks like the calfab ones, but it has the round imprint on the top center plate. When are you starting your build? It looks like a good pile of parts.![]()
Man looks a lot like that calfab. I have a build thread on here progress is slow waiting to get my forks axle and frame back from being coated. Need to clean my swinger up and get some bearings coming! lol
I'll have to check out the build, what gas tank and fenders are you going with?
Edit: The only dissapointment with both of our swingarms is that you can't run a 82 disc, but there has to be a way to stabilize the brake caliper and use a 82 axle and setup
Going to try to fix the little dent in the original tank and get it painted white. Then for fenders going to wait for a bit to see if we can get an order for white maier fenders on the way. But if not prob some red maiers. Rocking a black frame with the terry cable forks black also.
I wonder if the same manufacture made these swing arms and people just slapped there brand on it. I know aluminum DG swing arms look like Cal Fab also. My Cal Fab has the same dimple as your White Bros. I've saw post of a Cal Fab arm that was cracking around the welds so mine sees limited use nowadays.![]()
