Results 1 to 3 of 3
Thread: 250R front caliper ???
    Miami,Fla.(305)
    808
    Does a caliper rebuild kit (replacing rubber seals) usually resolve a sticking piston? -Assuming that the
    cylnders are free of corrosion etc. & pistons look ok too. One of the pistons has alot of resistance against
    the rotor. -I can squeeze both pistons back in but one requires more effort. Is it usually caused by bits of the seal that bulge out & get wedged in the cylinder after time/deterioation? Also,-are the K&L kits any
    good? (seals can be a big pain if theyre not exact)!
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Jun 2009
    Leander TX
    2,217
    Yes and yes.
    I used K&L kit on one of my trikes - maybe the 350X? It stops and doesn't leak.
    6,811
    Make sure your master is working right , the little vent hole near the piston when clogged will act like what your suggesting and hydraulic lock the caliper . I see this alot . I prob have a good front caliper if you need one Jimmy .
