Results 1 to 15 of 20
Thread: Loud Backfire
    JMiller's Avatar
    JMiller is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Loud Backfire
    What causes a 2 stroke engine to backfire when trying to start? I recently rebuilt my motor, started it,ran it for 5 minutes, then shut it down. Now when I try to start it, it backfires. What will cause this?
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    potsdam NY (upstate)
    1,437
    make sure you retorqe the head and cylinder bolts down they will coem loose and cause it to back fire like it is right now try that. my friends blaster did the same exact thing.
    looking for a TRI-Z 250 to restore at the moment
    LONG LIVE THE 2 STROKES !!!
    Dec 2003
    80
    back fire
    yea trailprotrailpro rings could be on backwards, or your reed valves could be too closed up , i asked me buddy on this
    1982 YTM 200 chain (102kph)(sold)
    1986 YTM200 ER (91kph)(oil pump gone i think, sellin' her for $500)
    1989 YFM 350 Big Bear (70kph) currently in use)
    2004 660R Raptor.. Got Her!!!
    1996 touring LE ( 140 kph) putup till' next winter
    YAMAHA-- NO COMPETITION!
    Cincinnati, OH
    3,289
    :shock: were is trailprotrailpro shock?
    speed20 is offline Check my feedback before buying from me Arm chair racerJust too addicted
    Jun 2002
    OH-IO
    816
    thats what im wondering 86 200x....looks like theres a bar or something in there!!! Where at in Ohio do you live 86 200x??? like what city?
    May 2002
    Texas
    2,670
    Guys, I believe the "bar" you are seeing is the linkage. That's the way older kawasaki UNI-Traks were designed. a push rod from the swingarm up to a rocker arm over the shock. which is behind his coolant reservoir and you can't see it.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    JMiller's Avatar
    Jeb is right, no "bar" on this suspension!
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    Oswego NY
    1,935
    JMiller.... That light looks TUFF on that T3!! I LOVE IT! The trike looks great, its nice to see 86/87 tecates being restored and cared for. When I first came to the board their was only a few guys w/ them. You did a great job w/ the restoration.
    Now for the back fire issue. What did you do to the motor? is the stator in the correct position? Did you time the KIPS valve correctly? Again w/ almost any running issue I look for wire conections. When the main plug from the stator has an issue (broken wire or dirt in it) it causes a T3 to do some funny stuff. Just a few ideas.
    GOOD LUCK Keep us posted
    MIK6 / Mike
    New England Ride 4/13
    JMiller's Avatar
    I replaced the crank seals, crank bearings, just about every other seal and new piston and rings. It started right up after i put the motor in and ran until i shut it down. The mark on my case is aligned with the center mark on stator.I timed the KIPS how the manual said to. I just dont know why it would run fine and now not want to start? Thanks for the compliments on my trike, I ordred a set of factory replica stickers, new rear fender, and a DG silencer.
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    Rittman, Ohio
    6,276
    What causes it is you kick it once, it dumps gas in the cylinder, and doesnt fire. You kick again, its dumps more gas in there, and doenst fire, and so on. So after about five kicks, it finally decides to fire, and "kaboom", theres your backfire. When mines does it, its seriously close to a fouled plug thats not firing consistantly, but if I get it started, which usually happens the next kick, the plug burns clean, and Im fine.
    Unless its happening an awful lot or while its running, its nothing to worry about. Its essentially an overcharge of fuel from an electrical system that did not fire every time. If its amything more serious than a plug, it will do it after it satrts, while running.
    JMiller's Avatar
    I pulled my flywheel and found the stator aligned to the center mark. My manual said to align it to the mark on the right.
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    I like the street bike lights you put on the front, do they actually work?
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    i can't answer your question but that sure is a sweet kawi!!!!
    YAMAHA'S: 84 225DXL
    04 POLARIS SCRAMBLER 500 4X4
    05 kazuma 50
    JMiller's Avatar
    Yeah the lights work great, could use a higher wattage stator though. 8)
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    May 2002
    Texas
    2,670
    Man I'm with Mik6, I love the headlight! May pick one up just to retire mine to the shelf since it's still in great shape!
    Did shifting your stator to the factory recommended setting help any?
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
