See Pic!
See Pic!
1986 Tecate
1984 Tecate
1985 Tri-Z
1986 ATC350X
1985 ATC250R (2)
1985 ATC125M (2)
1982 ATC70 - Original Owner
3-Wheelin' since '82
It's a fender support bracket. If you have Maier fenders, you may not have one. I don't have one on my 85 but have it for my 86.
It's not a critical part.
chris is correct....fender support..although if you do alot of jumping you might want to put one on......i see them on ebay occasionally $10......i made my own from a piece of thick wire i found on the job...works ok...good luckOriginally Posted by ChrisD
1985 ATC 250R
2006 TRX450ER
RIDE RED...IS THERE ANYTHING ELSE??????????
THERE IS ONE ON EBAY NOW. UNDER 250R
KEN,
Dude, please dont type in CAPS. It is considered yelling and rude online, you seem to do it on every post.Originally Posted by sucatta
'04 450r, hr +3 stroker, s2 hotcam
'84 Honda 200x
slow restro
Previous rides 82 Yamaha yt175, 85 Yamaha 225DR, 84 Honda 200M, Ski-doo Olympic 340
is this better. jeeeeeez
My maier fenders aren't made for that support. Does anyone use them on their maiers?
I want a race honda with reverse.
I have a set of Maier fenders on my 85 and it doesn't use it.
My 85 has Maier Rear Fenders. And I do not have the brace unless its between the seat and fender or something. I won't be getting one.
Thanks Guys!
1986 Tecate
1984 Tecate
1985 Tri-Z
1986 ATC350X
1985 ATC250R (2)
1985 ATC125M (2)
When you buy MAIER fenders they give you 2 rt angle brackets to use because they don't have anything molded in the plastic like OEM does. It requires that you drill 2 holes in your new fender and then have to look at a machine screw head all the time.
My 85 ATC250R Maier fender is strong without it.
My 87 ATC250SX with the mudflaps flops down from the weight - especially once mud gets on there - and it could benefit by using the support. I still don't want to drill any holes though.
