here's some help for your pull start this one is off of a ytm 200k, but other than the decompression system in the bottom it is the same as the dx, and will work on a dx, or dr. Make note of one point I say in it about greasing the rope after putting it in, this trick will give your rope a longer life span by far and reducing wear on the housing, also I point out areas of where to grease , so your pull is easier, and I describe how tight to go with the tightening nut. If you want I can do a complete tear down of a dx/dr pull start to show you on your exact housing. http://www.youtube.com/watch?v=eBhtlWumtlI
On a side not I actually used the pull start in the video for quite awhile on my 200k project trike with no problems till I got a great deal on a 225 pull start and then sold the 200 one for cheap.
