Thread: Yamaha 225 electric start / rear-end question
    May 2003
    Shediac, New Brunswick
    1,126
    My electric start just makes a click it is coming from a black box that is under the fenders. Now before it did turn my starter over a little bit like probably 4 turns on the starter, and did not turn the engine over. My question is could it be that it just does not have enough power to engage the starter to touch the other gears... So would I just need to charge my battery, do you think that would fix all my problems or is there something else wrong?
    Now the rear-end I can turn the wheels about 2 inches back and forth trailprotrailpro they catch ... So what would that problem be the gears?
    '84 Honda 200x
    slow restro
    Washingtons Crossing, Pa.
    2,977
    The rear end just sounds like normal free play on the output shaft that would disappear if the motor was running - I wouldnt worry about it. It sounds to me like you either need a new battery or probably need to charge the one you have like you said.
    Nov 2002
    Kirkville, NY
    3,831
    The clicking is the starter solenoid working, there just isn't enought charge left in your battery to spin the starter motor. Start by charging the battery or replacing it if it is not holding a charge. Remember, batteries have to be replaced every few years.
    -Andrew
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    yeah..try a new battery. the same thing happened to me. plus i had blown some fuse trying to jump start it so i wouldnt try that. good thing my buddy found that fuse because i was pulling my hair out.
    YAMAHA'S: 84 225DXL
    04 POLARIS SCRAMBLER 500 4X4
    05 kazuma 50
    atckowalski is offline Formerly "aaakowalski" Arm chair racerJust too addicted
    Nov 2002
    Northern Mi.
    516
    On my 225dx, even with a new battery, it won't start cold with the electric start, but it will once it is warm.Try pull starting it while you hold the starter button down if its really hard to pull like mine.My dad does that,when it is cold, to make it easier on himself I guess.
    Before it was , dad fixes it, I take off on it.
    Now it is, I fix it, He takes off on it.
    What in the hell is up with that?
    yarmouth
    4
    Question
    I just bought a 225dr and it starts first pull everytime. I havnt bought a battery yet to try the electric start. But when i drive it and put it in gear it makes a noise wheni touch the throttle and when i start to go fast it stops then wheni crack on to it and jams up and stuff. The guy i bought it from said it needs new back bearings , could this be true? help me alot thanks
