Results 1 to 2 of 2
Thread: new score 1985 250sx with orig title and paper work 475 bucks!!!!!!!!
    rouseanator's Avatar
    rouseanator is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2012
    lynden washington
    209
    So it runs good took it out riding once and it seems that the swing arm bearings have gone out first i noticed that it was riding kinda funny and was slipping outa gear alittle thought it was the shaft but then i noticed that it was tilting side to side more than it was looks to be the swing arm bearings did alittle research and looks like they can be a pain to change im going to attempted it anyways any pointers...... also none of the lights worked neutral reveres headlight etc so while im waiting for parts im messing with it spent most of the day working on it oh and also the electric start doesn't work it does when you touch both the bolts on the solenoid with a screw driver so thought I needed a new solenoid and that might be why the lights dont work but it ended up i took the solenoid off my bigred 250es to test it and it was doing the same thing so it ended up being the ignition was toast the key didn't work and the key was stuck in the ignition and the black and white wire and the green wire were off so messed around checking everything for hours and then just cut off the ignition and just put the red and the black wires together and bam every thing works neutral reverse and headlight and also the electric start what a relief so now gota do these damn bearings I hate messin with bearings prob going to make a video as I do it to help some other folks out so if you have any pointers please let me know thanks guys
    Feb 2013
    chicago il
    505
    your going to need a torch, the only way that swing arm retainer will move is when its orange hot. and you will need to make or buy the special socket to fit it. good luck
    Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
    Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
    Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
    KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
