Results 1 to 7 of 7
Thread: Auto x help!!
    Nov 2012
    Waldoboro, maine
    791
    Auto x help!!
    I know there's a ton of threads about the auto x but I haven't seen this problem come up.
    I'm having a hell of a time mounting my 85 200s motor in my 85 200x frame. I'm using the first gen x mounts and whenever I get one in none of the other ones line up.
    Is there a certain order or trick to putting in motor mounts?Click image for larger version.
    82 250r
    83 Big Red
    85 Auto-x
    If you've done business with me please leave me feedback
    http://www.3wheelerworld.com/showthr...ght=Bren_downe
    Nov 2012
    Waldoboro, maine
    791
    Sorry for the sideways pics. I should mention that the down tube has been dimpled to accept a e start. Could this have bent my frame? Still looking for answers.
    82 250r
    83 Big Red
    85 Auto-x
    fingerlakesny
    2,834
    possibly bent frame . do you leave all the bolts loose till ya get them all started ?
    250r dust runner
    nicker71's Avatar
    nicker71 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Wright City, Missouri
    385
    Quote Originally Posted by 124356q View Post
    This is important, keep them all loose and get all the bolts in first. I had a bit of a hard time with mine too, I used a pry bar and pulled hard to get it to line up
    Nov 2012
    Waldoboro, maine
    791
    Yeah, even with the down tube ones loose I can't get the ones near the sprocket to go all the way through. The one with the two spacers will go through the frame then spacer and case, but then on the other side of the case the spacer is too long and the last hole on the frame doesn't line up. It almost looks as if the tab on the frame was bent in slightly. Heat and beat?
    82 250r
    83 Big Red
    85 Auto-x
    Jun 2012
    delaware
    100
    i started on the backside and bottom of motor then the one above it as far as mounts and bolts go. this was the only way i could get the rest to fit.
    Nov 2012
    Waldoboro, maine
    791
    Thanks for the input, just wanted to check with everyone before I went to the pry bar or ended up breaking a bolt or cracking my case.
    82 250r
    83 Big Red
    85 Auto-x
