Results 1 to 15 of 17
Thread: Deal of the Day!!!! Maybe of the Year...
    Jan 2008
    Willowbrook, IL
    856
    Have to say I scored !BIG! today. Picked this up from a couple of guys who said that they haven't had it running for about a year and either the trans is bad or the shifter. Either way, I'd say it was a score. Best of all, I got it for $100. Yes, that's right $100. They wanted $200 but since I had to wait on them for 45minutes and they did not mention the bad trans/shifter originally, I got if for a STEAL!!!! Question is though, how easy is it to fix a trans?
    Attached Thumbnails Attached Thumbnails BR1.jpg   BR2.jpg   BR3.jpg   BR4.jpg   BR5.jpg
    85' Honda Big Red
    09' Yamaha YZ 250F
    2012 Polaris Sportsman 500 H.O.
    2015 Polaris RZR 570 LE/Trail Edition
    2017 Suzuki DR-Z400SM
    Dec 2010
    845
    Get it running and go from there! nice score
    MY TRIKES! :
    1- 85 250r NOS engine
    1- 1985 350x
    1- 82 250r + Parts
    1- 86 250es Big Red
    1- 85 200x
    2- 84 200es Big Red
    1- 84 200M !!MINTY!!
    1- 73 Atc 70 (project)
    MY Snowmobile's!!
    1999 Polaris Indy 440
    1999 Ski-Doo 583
    1993 Polaris Indy 500
    My Dirt Bike
    1986 Dr100
    Central Point,OR
    465
    I have never been inside the Trans of any ATV so I cant help you there but you definitely scored a killer deal! I have been around a lot of 250 Big Reds and owned one myself along with a 250sx and I have never seen one have tranny problems but obviously it's possible. That thing looks really good though no matter what you find wrong with the engine!
    Sarnia, Ontario, Canada
    3,415
    If the only thing with the trans is that the shift won't return then you're a bandit..
    Get it running, pull the left engine side cover and see if the shift return spring pin is broken and replace it.
    And you're right if that is the only thing wrong, it is the steal of the century!!
    If its more serious then the motor is coming out and you have to split the case to start internal parts inspection.
    Good luck and good score either way..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    fingerlakesny
    2,834
    good deal,,,ive had alot of es/sx and only had 1 with a bad 2nd gear ...and 1 with a bad spring..both on sx's so good luck to ya...
    250r dust runner
    mooseknuckle's Avatar
    mooseknuckle is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2013
    The Granite State
    198
    Start simple and just make sure the shift isn't stripped allowing it to spin on the shaft. Some people have a tendency to put to much weight on the shifter. Nice score!
    NEPA
    7,051
    What a steal. Congratulations ! That is a 1500 mile bike. Doesn't get much better than a 86 Red
    Oct 2011
    Abbotsford BC Canada
    93
    I got if for a STEAL!!!! Around here for that price it would be stolen That looks in awesome shape, congrats on ya the deal of the day!
    Dec 2009
    Springfield, Missouri
    527
    That is steal anyway you look at it.
    1- 87 200x
    1- 87 Big Red 250ES
    1- 87 200x SOLD
    2- 86 200x SOLD
    1- 86 250R
    1- 86 350x
    1- 86 350x SOLD
    3- 85 350x
    1- 85 350x SOLD
    1- 85 200x SOLD
    2- 85 Big Red's
    1- 85 250sx
    1- 85 125M
    1- 85 ATC 70
    1- 84 ATC 70
    1- 74 ATC 70
    1- 73 ATC 70
    1- 81 ATC 110 SOLD
    1- 86 TRX 70
    1- 87 TRX 70
    1- Zinger
    1- 84 Tecate
    kebby28's Avatar
    Nov 2012
    Antrim, NH
    435
    Nice find!!!
    Oct 2012
    WI
    499
    Ive taken apart the transmission on my 200x and its terrible to get back together, Just bring it to a mechanic that knows what hes doing, i wish i did.
    nicker71's Avatar
    nicker71 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Wright City, Missouri
    385
    Thats a great deal, good luck on getting it repaired. Ive bought several $100 hondas in the past 7 years but never had to tear into the engine to get it running. None of my 100 dollars hondas ever looked as nice as yours.
    Dec 2012
    812
    Okay, now let's here the story of how you found this thing!
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Apr 2012
    USA
    4,129
    As the others said, that is a steal! I paid over $200 for my parts SX machine, non-running and the shift fork on the shift shaft was broken (not the internal trans forks). Easy fix, had the parts, and then I found out the kick starter 1 way bearing was bad.
    So there are the 2 common problems with the big red/sx engines. More or less if the shifter is on the shaft good, then check how it returns. If it returns well with a solid shift then either nothing is wrong, or it is an internal issue, debug more .
    If the shifter does not want to return at all, shifter spring pin is broke, I heard it is common, but never seen one bad. Heard the new pin is still in stock at honda.
    If the shifter returns well, but has a lot of "slop" before it seems to do anything, I would say the shift fork is broken on the shaft. Easy fix, but requires both sides of the engine to be poped apart. The manual will help you line things up correctly, and the part is around $20-25.
    Looks like you need a left side cover, I'm pretty sure I have one around if you are interested in making it OEM complete. Get a right fender and fix the engine problem and you should have a $1500-2500 machine depending how clean it really is (photos don't always tell the whole story).
    May 2009
    Minnesota
    457
    Awesome find! I love the 2nd gen BR's.
    1982 Honda Big Red 200e
    1985 Honda 200x- sold
    1986 Honda 125m- sold
    1986 Honda Big Red 250es
    1986 Honda 250sx
