Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: Deal of the Day!!!! Maybe of the Year...
    Nov 2010
    Oshawa, On, Canada
    2,123
    I can almost guarantee all you need is a left side gasket and the shifter pin. I've done this one 4 different es /sx's when they wont shift...
    pin part number. PIN
    24652-HA0-000
    # 21 on the schematic. http://www.servicehondapsn.com/fiche...85&fveh=131327
    All you need to do is drain the oil, take the left case off, pull the shifter shaft out, behind that you will see a broken pin, pull it out with a screwdriver ( will be loose already ) and put a new one in.
    The reason this happens is that honda didn't use enough torque when installing the pin, the pin starts to back out of its threads from vibration, the pin will bend , and make the shifter not return sometimes, then it will break and wont shift at all.
    I've done this on both my ES and SX, and a few of my friends...
    Goodluck! Nice find.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Dec 2002
    374
    i agree with jason125m. done that fix before
