Results 1 to 15 of 16
Thread: ATC 250es leaks oil where exhaust meets head!
    Feb 2013
    Adelaide
    127
    Exclamation ATC 250es leaks oil where exhaust meets head!
    Does anyone have any idea why?
    -Thanks Alex
    Jan 2011
    Choctaw, OK
    2,755
    Its probably coming from the oval cover above the header pipe. These motors have a tendency to leak there. The oring under the oval cover doesnt seal well.
    Feb 2013
    Adelaide
    127
    Should i tighten it?
    Jan 2011
    Choctaw, OK
    2,755
    No, replace the oring or coat the mating surfaces with a thin layer of sealant.
    Feb 2013
    Adelaide
    127
    Nah its not that i wiped the oil off started it up but it leaks directly from where the exhaust connects to the head...
    -Alex
    Feb 2013
    Adelaide
    127
    Heres a pic its a bit hard to see...
    Jan 2011
    Choctaw, OK
    2,755
    If thats the case then I suspect the valve stem seal is bad.
    Feb 2013
    Adelaide
    127
    How would I replace it?
    Jan 2011
    Choctaw, OK
    2,755
    The head has to come off.
    Feb 2013
    Adelaide
    127
    Looks like im back to work... hahaha
    -Alex
    Feb 2013
    chicago il
    505
    that ovel cover was a good start. are you sure that the valve cover is not leaking. it is that case that the oval cover mounts to. basically the top half of the head. it looks dry in pic but look before you assume valve seal.
    Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
    Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
    Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
    KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
    Jan 2011
    Choctaw, OK
    2,755
    Ya I agree. I think you should power wash the head real well and fire it up. the leak path should be very clear.
    Feb 2013
    Adelaide
    127
    Heres another photo and yeh cleaning it sounds good i will attempt it later.
    shovelryder's Avatar
    shovelryder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2012
    Buffalo, MN
    427
    Sure looks to me like it wicking down from the top of the motor????? I have an old harley.....LOL.....Ya learn to see trails.....
    Jan 2013
    minnesota
    5,911
    Hello
    IF you wiped off oil from the valve cover area before the photo the valve cover is obviously leaking. As shovelryder mentioned, your photo clearly shows old burnt oil stains where it was coming from the cover at some point and running down all over the head and cylinder fins, it's plain as day! Of course the gasket may have been replaced but if there was ANY oil on the TOP side of your fins ABOVE the uppermost level of the exhaust then the gasket is burnt to a crisp from prolonged exposure to heat.
    It may also have a SMALL leak at the ex gasket which could be either guides, guide seals and/or piston rings but you should hear a slight ex leak if the ex gasket is leaking.
    Does it smoke white or light blue gray smoke? If so you are burning oil and need to do a compression test before tear down then check cyl bore for out of round and taper if ok then deglaze before installing new rings.
