Thread: Can you use a '86 250R switch on an '85 350X?
    May 2003
    Houston, Texas
    2,409
    I saw a pic of an '85 350X with an '86 switch. Not sure if the switch is from an R or a 200x but its the newer style colored button switch.
    Can you use that switch on a 350X?
    The R and X ones are available.
    Also are these OEM or some knock off? 59 bucks is pretty cheap:
    http://www.ebay.com/itm/L-H-Switch-H...3a4715&vxp=mtr
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    May 2003
    Houston, Texas
    2,409
    [IMG][/IMG]Click image for larger version.
ID:	164854 Here is the bike I saw this on....
    Dirtbikes:
    1988 Yamaha DT
    Jan 2011
    Choctaw, OK
    2,755
    You can but you will need to reconfigure the plugs. For the most part, the switch assemblies wer the same, it was the harnesses coming out of the switch that were different. Whats your electrical skills? Do you have a meter and know how to use it? I have a TRX switch on one of my SXs. I had to make a couple of changes but it works great and I only paid 30.00 for it new.
    May 2003
    Houston, Texas
    2,409
    Great thanks!
    Dirtbikes:
    1988 Yamaha DT
