Results 16 to 30 of 43
Thread: New to the fourm
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    One more pic to keep people guessing.
    The Goal... All I Need Is The Time...
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    ...and here is the WHY as to this little frame/suspension mod.
    To make room for this little number. No way to make this setup work with the stock suspension on a 200x frame/swinger and a 1985-86 250R shock would extend too far up and into the way. Where there is a will...
    Mar 2013
    Minnesota
    441
    Nice work!
    ~~ATC's Currently Owned~~
    1983 Honda 200x - Main ATC
    1985 Honda 200x - Parts Bike
    ~~ATC's Previously Owned~~
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1983 Kawasaki klt 200a
    1986 Honda 200s
    ~~Other Toys Owned~~
    2012 Pro R 800
    1993 Polaris Indy 500
    2004 Yamaha 125
    1990 Thunder Kart - 250CC
    2001 Yamaha Blaster - 240kit, aftermarket exhaust, power reeds
    Oct 2011
    Lilly PA
    601
    Yes nice work!!!!! And Hi and Welcome to this site..
    86 Tri-Z
    86 Honda 250R,
    84 Tecate
    Larry T Moore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2013
    Indiana
    358
    Sweeeeeeeeet!........and a Howdy from me to you
    Mar 2013
    Minnesota
    441
    looks like shes coming together!
    nice job
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1986 Honda 200s
    2012 Pro R 800
    2004 Yamaha 125
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    Hey... thanks, guys. Believe it or not, there is a method to my madness.
    Here is what had to be done to the backbone in order to get the carb in and have a path for the cable routing.
    The carb requires a splitter / Y cable that I need to make yet. One lead lifts the slide and the other actuates the accelerator pump.
    Just to be clear, the engine that is sitting in the frame is NOT the one that will stay in the bike. It is there for building purposes and testing. The real mill, has yet to be completed (next winter in the wood shop). And the carb and intake pictured, will only be used on the new engine but the frame changes had to be made, either way.
    Mar 2013
    San Angelo, TX
    81
    Quote Originally Posted by Dave8338 View Post
    ....The first three wheeler I ever rode was a 185S with the front suspension and it was such a blast that I vowed to someday have one of my own. That was back in 1983. Fast forward 30-years, a wife, two wonderful children, and a few wheelers, and I'm right back to where I started. This time around, I have a bit more money to play with and lots more tools. I'm building my dream 185S and yeah I know... "why a 185S" is usually the question I hear first. To that I say, because I want one. ...
    That sounds familiar!
    Fred
    Retired Army Guy
    1982 Honda ATC 185S
    1985 Kawasaki KLT160
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    Making spacers for the sprocket hub to offset the sprocket/chain 21mm inward towards the center of the machine. As mentioned, alignment or should I say clearance was going to be close. Also chose to add a little length to the linkage mounting tabs on the swinger in order to gain a bit more ground clearance. This results in a loss of travel by 1/2" so total suspension travel will be just south of 8". Was willing to make that sacrifice as I don't plan on getting this thing air born and also didn't want to drag the dog bones through every puddle. Rear wheels are Douglas with Holeshots mounted. Kenda Front Max. Not going for a flat tracker nor a mudder. Just a comfy hammock suspension that IF I've done my math correctly, should do the trick. We'll see...
    Mar 2013
    az
    20
    Welcome dave....Looks like a fun project!
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    Received a few more crucial parts yesterday. This thing is going to come down to the wire as far as the next weekend deadline !!
    Likely won't have the rear plastics mounted (had to cut the original 200X seat latch mount out of the frame and rework it so it fits the 185S seat/fender combo) so I may have to settle for a plywood seat and a few zip ties to hold it in place. HEY... I could call it a Cafe Style trike and consider it done. NOT ! Here is a pic of that and the shortened lower linkage:
    This evening will be mounting up the chain guide/tensioner on the front, topside of the swing arm. If I can get it right, I shouldn't need a spring mechanism as I'm using a guided roller for the 520 chain. The "plan" is to mount it so that as the swing arm moves up, the cam-roller rotates forward on the axis and keeps the tension equal between the roller and the front drive sprocket. By doing this, I should be able to go without the chain slider on the front of the swing arm. ALL speculation at this point but I will know in the next 24 hours if it is going to work.
    Time will tell...
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    Here is a shot of the 21mm spacers that offset the sprocket inward. Turned out well. I only took the time to shape one of the spacers at this point as I'm running out of time. I'll do the other three when I have a little more time to play.
    Had to do a bit of filing and shaping on the bearing carrier and sprocket to get things to clear but nothing major.
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    Frame and swinger are painted. New bearings on the front of the swing arm, and sealed rollers for the bearing carrier that I hope to have in tomorrow, if all goes well. I intend to keep all of the original 86 hardware on the pivot bolt so there is going to be a it of a trick, in order to retain the bearing seal washers, in the game. For this weekend, I'll go without the inner seal washers. When done, they will be there...
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    We have Paint !
    We have paint ! Nothing too fancy but I wanted it in gloss black like the 185S was. Red just wouldn't look right, IMHO. Swinger is done in Gold Metalic that is a good match to the Pro Link decals. Just something to keep it from rusting for now. Had the paint on hand so why not.
    Cleaned up and ready for primer:
    And some High Gloss Black:
    Assembly will happen on Friday. Hope to have it all together and ready for some testing by Sunday morning.
  15. #30
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    Bearings and seals in the carrier and the axle cleaned, prepped, and clear coated. Paint up the motor mounts and foot pegs, bars, and make my plywood seat, tonight. Tomorrow things go together.
    Saturday, bring the thing to work and leave directly from work to the "party". I'm saving the electrical for Saturday evening and Sunday I hope to ride...
