Results 1 to 10 of 10
Thread: Help pull starter rips out of hand and hard to start.
    Mar 2013
    grass valley
    I have a 1979 Honda atc110 the pull starter rips out of my hand every two or three pulls. Does anyone know why this is happening. How do you fix this issue. It is hard to to start, but once it starts it ides fine and has no issues running. Once you turn it off it almost never wants to start until it is cools down again. It then does the pull start ripping out of my hand thing. I have a new spark plug, new oil, new gas, carb cleaned, new air filter. Does anyone have any ideas or suggestions on why the pull starter is ripping out of my hands and why it is so hard to start and to get restarted? Thanks so much, Nathan
    Pacific NW
    4,255
    Barring the really obscure, I'd check ignition timing if you can.
    click on
    service manual
    There may be a spark advance plate around the cam that advances the timing.
    It has 2 little springs that can break or the plate can get stuck in, say, an advanced position and kickback (rip the rope outta yer hands) and it may happen all the time or occasionally and the hot or cold factor may just be coincidence.
    Why would it change after it cools is a great question I'll hafta think about.
    ps - Sounds like it's trying to fire too soon the upstroke and man that Does hurt.
    Try getting whacked in the shin when that happens with a kickstarter (NO don't)
    You'll get it, we always do.
    Feb 2013
    chicago il
    505
    I agree with tri again it is definitely a timing issue.
    and try being on the kickstarter when that happens. sheared the key on my 84 250r and went to kick it and it almost threw me off the bike when it fired against kickstart. I wasn't expecting that.
    Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
    Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
    Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
    KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
    Mar 2013
    grass valley
    I'll check out the timing today and the advance plate out. Thanks for the fast reply's. I will let you guys know what I find out. Thanks again Nathan
    Sep 2011
    Ocean Beach, CA
    1,333
    Better start eatin your wheaties!
    Michigan UP
    1,005
    Put down your purse, grab the handle, and give it a PULL.
    83 200e is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2012
    Fisher, MN
    251
    good compression maybe
    annapolis royal, nova scotia, canada
    43
    common now I used to yank on my first 200 so hard it lifted the wheel off the ground. Then the rope snapped...
    replaced with stronger smaller longer rope so i could just grab the handle on a cold day and run! she'd always start then...lol
    __________________________________________________ _________________________________________________
    85 350x ------almost mint
    99 banshee --heavily modified
    04 yfz480 --- heavily modified
    83 200x -----build in progress
    Oct 2012
    Somerset County PA
    720
    ^^ that's what I used to do except my 3 wheeler would almost tip over from pulling it so hard, I bought a price of 1/8 inc wire and put it on but it did not work at all, so if I were u you I would get a medium thick strong regular rope and make sure you tie that sucker good ( 2 to 3 maybe even 4 knots depending how thin)
    Quote Originally Posted by Howdy View Post
    Yea, looked like a monkey ******* a football. LMAO
    Howdy
    Currently Own-
    84 250R My Baby/Project
    83 Yamaha 225dx
    79 Honda Twinstar - Big Ole Turd
    Heres My Feedback Page
    http://www.3wheelerworld.com/showthr...for-ColtonGG33
    Dec 2012
    Plymouth, Massachusetts
    68
    The ignition timing is too advanced. Service the mechanical timing advance plate at the ignition points.
    Additionally, my experience with recoil pull-starters is as follows: Slowly pull out rope until piston travels just PAST TDC to the power-stroke. Then allow rope to recoil then pull the rope smartly to start engine.
    This method allows a full 540 degrees of easy crankshaft revolution; enabling the rotating assembly to spin up and develop sufficient kinetic energy to easily drive itself through subsequent compression stroke without overloading the pull-starter rope/mechanism. Both your machine and shoulder will thank you by providing a long service life
    Quote Originally Posted by nathanhooker View Post
    I have a 1979 Honda atc110. The pull starter rips out of my hand every two or three pulls. Does anyone know why this is happening?
