So here is a pic of hte stator from my 1986 kx500
THe way I undersand it one sice it so trigger the CDI and the other is to Charge the coil?? Is this even true
Okay now the complicated part. Can I move (will cut grind rewind if necessary) the charging coil to ontop of the ignition coil so I can build a custom lighting coil for hte other side tha will now be avaiable
