Thread: how to remove tri z triple clamp?
    pcs's Avatar
    pcs is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2011
    yuma, az
    465
    my tri z feels like its binding when i turn the bars full left or right. i want to take the triple clamps and look at the bearings inside but what socket do i use remove the nut under the top triple clamp, the nut that has the notches in it. tried to search here on the site but couldnt come up with anything.
    thx
    Team Blue: 85 Tri-z 250: under the knife
    Team Red: 87 Trx250r 01Cr80 15 CBR600RR
    Team Yellow: 06 Ltr450 11 Hayabusa
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    There are special spanner wrenches for those however, a brass/bronze drift and a small will have it off just as quick. If you don't have drift (punch) you can use a piece of hardwood. Pine or other softwood will not cut it, usually. Hope this helps. Good luck.
    The Goal... All I Need Is The Time...
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    thanks, that nut looks just like one for a yamaha sport bike swing arm bolt but i dont want to spend over $30 for a socket that doesnt fit. might give the hard wood a shot if i can find a spanner that works.
    Terryville,CT
    1,616
    i've always used a large socket with the handlebars off.
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    what kind of socket did you use to grab the notches?
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    a swing arm clamp bolt from my stock ltr 450 swinger has a square end that fits great in the boxed groove. few taps with a dead blow and it was free. bearing at the bottom was dry so cleaned it out then re packed it. the bearing on the top with the steel balls was clean but the were free with nothing holding them??? is that how it is suppose to be? cleaned them out then re packed them too.
