ride red is right on. you have to rock it to get through all gears and the hi/lo box has to be engaged in either setting for that to work as well. that hi/lo shifter gets rusty and wont move as far as it needs to. take the cover off and remove the e-clip and the shift fork, then you can slide the lever out through bottom of case. wire wheel it and apply a dab of grease and you should be all good. make sure you reassemble properly or fork connected to lever will not move the fork that moves the gear and you will be at square one again. you should be able to feel it click into each setting when moving lever.
Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
