Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 42
Thread: Polsihing Fenders...what gives?
    May 2003
    Houston, Texas
    2,409
    Man... oh man....
    I am not sure what I am doing wrong here but the rear fender is way harder than the front. I think its a different grade plastic. Seems softer.... the front fender is more like the 250R tank.
    Here are the shots.
    I started with wetsanding at:
    160 - this was dry sanded..is that my trouble? Are these the dry sand scratches still there?
    220
    600
    800
    1500
    2000
    3000
    Wool pad - swirl remover
    Wool pad - polish
    3 M compound - foam pad
    3 M Machine Polish - foam pad
    Here is the pic:
ID:	165412Click image for larger version.
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Plattsburgh, NY
    2,311
    I think 160 220 and 600 r way too heavy. They make such deep marks its impossible to get them out. Just my thought on it though.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    May 2003
    Houston, Texas
    2,409
    You might be right....so wonder what to do now?
    Dirtbikes:
    1988 Yamaha DT
    NEPA
    7,051
    Correct. I have never polished one yet, But ,I 'd say 4-500 would be the most aggressive you should have started with. You'll get them.. You're just gonna have to wet sand your hands off!! Good luck !
    Sep 2012
    Indiana
    460
    Had that same problem w/ my 200x front fender and that was the only conlcusion I could come up with. Start in the 400-500 range. I started with 180 wet sanding the whole process and never could get all my sanding lines out and I sanded a lot!! Eventually, I just used a product called New Glass 2. It basically just puts a clear coat on the plastic, but man does it shine. I put about 10 coats on my fender and it sealed up a lot of the sanding lines that wouldn't buff out. I don't know if it holds up long term, but this fender looks brand new for right now.
    fire1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    Roanoke,Virginia
    404
    The compound should be used first after the sanding on the wool pad. The polish and swirl remover are to remove the the swirl and fine scratches left from the compund and wool pad. The compound is a cutting agent. Remember I said the fenders are more difficult and I agree the rear fender seems to be slightly softer compound.
    May 2003
    Houston, Texas
    2,409
    Yes I did get the 3M compound and will work on that.
    I also think I might have to go in and work the 600 grade like crazy. Will I ever get out those deeper ones? Or should go rougher?
    Dirtbikes:
    1988 Yamaha DT
    Jul 2008
    Roanoke,Virginia
    404
    Are the deep ones scratches that were there or caused by the sanding. On deep scratches I normally use 320-400 on a DA sander till there gone then wet sand. I only use the DA sander on the deep scratched area.
    May 2003
    Houston, Texas
    2,409
    no I think I made those with us some deep sanding on using a pretty course grade so I'm wondering do I get the next grade finer and then wet sand wet until are gone or what
    Dirtbikes:
    1988 Yamaha DT
    May 2003
    Houston, Texas
    2,409
    Is a DA sander an orbital or rotary?
    Dirtbikes:
    1988 Yamaha DT
    shovelryder's Avatar
    shovelryder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2012
    Buffalo, MN
    427
    DA is dual action. Same as a random orbit pretty much. Spins and gyrates.
    May 2003
    Houston, Texas
    2,409
    Alright...I"ll be back on it tonight...coffee brewing late night and the sanders going wild.
    I'll post some update pics!
    Dirtbikes:
    1988 Yamaha DT
    May 2003
    Houston, Texas
    2,409
    Great video here:
    Dirtbikes:
    1988 Yamaha DT
    Apr 2012
    coshocton
    159
    600 and plenty of time,and go up from there, and it will be like new...but you are gonna have to put in some hours in,but you will be happy with the out come
    (got to agree with crazy70man) 1 VERY UNDERSTANDING WIFE
    1985 TRI Z 250
    1985 1/2 TRI Z 250
    1986 TRI Z 250
    1985 250 R
    1986 350 X
    1985 225 DX
    1986 KXT 250
    1987 BW 200
    1983 YTM 200
    1985 BIG RED X 2
    1985 HONDA ODYSSEY
    2001 YZ426F X 2
    2012 TRI Z 426F (project)
    1986 TRI ZINGER
    1982 HONDA 70 X 2
    1999 HD WIDE GLIDE
    1977 HD GOLF CART X 2
    1999 YAMAHA GOLF CART X 2
    Dec 2009
    illinois
    1,765
    Well said, I always started with 800 grit then moved my way up, Also NEVER dry sand, that just makes more scrathces and always rinse off the fender and sandpaper. When wet sanding ,plastic will build up in the sandpaper and will scratch the plastic if you do not rinse often. Here is a picture of a 200X fender I sanded and buffed with a synthetic wool bonnet, I never used any polish at all, it looked shiny and almost NOS, you can only see super fine swirls in the direct sunlight and in the shade it looked PERFECT. I would say polish with Nano wax on a foam pad would make it perfect but i am not sure. The 86-87 200X fender has NO wax or polish on it, just the result of 2000 grit wet sand and a random orbital buffer with a synthetic wool bonnet dry buff with NO compounds used.
    Attached Thumbnails Attached Thumbnails 100_1177.jpg   100_1227.jpg   100_1218.jpg   100_1212.jpg   100_1214.jpg
