Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: 2 speed tri zinger vid
    Fox Valley Wisconsin
    35
    Quote Originally Posted by fastatc70 View Post
    Wow that tri zinger brings back memories. What bike did you get 2 speed motor from? A friend of mine has my old zinger he wants to build it to keep up with my atc70.
    Its from a towny, good luck finding the engine or parts, they only made them one year and alot of the qt guys grab them up, I paid $200 for my blown up towny engine. Thats weird, I actually raced a stock atc70 with my original zinger engine in and we were dead even, He did have smaller shifter kart tires on it though!
    current trikes:
    84 225dx with HID
    2 Speed tri Zinger
    2 more tri zingers and 4 zinger
    I had:
    82 atc70
    80 tri moto yt125 with Dt175 topend
    35
    Good lookin rig, now if i can fit all 4 zingers in there?
    current trikes:
    84 225dx with HID
    2 Speed tri Zinger
    I had:
    82 atc70
    fastatc70 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Northbrookfield, Ma
    166
    Wow I have been doing this for a while and I have never heard of a towny. What year what is it?
    Trikes:
    1985 ATC 70 mod to 184cc
    1984 ATC70 mod to 124cc
    1983 ATC 70 Xmas restoration
    Quads:
    1986 TRX 250R
    2002 TRX 400EX
    2- LT80 for the kids
    1986 LT 50
    kzr800's Avatar
    kzr800 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2011
    USA
    167
    Very cool, I would like to hear more about the 2-speed mod. I have a Zinger I want to pimp out.
    2008 Arctic Cat - Z120
    2005 Kawasaki - KFX 700
    2005 Kawasaki - KFX 80
    2004 Arctic Cat - Firecat F-7 EFI Nightfire
    2001 Arctic Cat - ZR800
    1999 Arctic Cat - ZL 600 EFI
    1993 Arctic Cat - Thundercat 900
    1991 Arctic Cat - El' Tigre EXT 530 (2)
    1986 Arctic Cat - Kitty Cat
    1985 Honda - 250R ATC
    1985 Honda - ATC 70
    1985 Yamaha - YT60 Tri-Zinger
    1983 Yamaha - V-Max 540
    1981 Yamaha - SRV 540
    1981 Scorpion - Sidewinder 440
    1973 Arctic Cat - Kitty Cat
    35
    TOWNY 2 SPEED TO ZINGER MODS engine is from a 1982 yamaha towny MJ50. If you get a complete towny engine its a fairly easy swap, i always split the cases on my engines to inspect, all your out is the 2 intake gaskets, base gasket and maybe the side cover gasket, they use yamabond to seal the case halves. when they are apart i remove the kickstart and oil pump and related parts, I dissassemble the oil pump remove all parts and fill it in with JB weld to use it to plug the hole in the case. You can order the plug for a zinger case to block the kickstart hole. the flywheel and stator ARE DIFFERANT, the flywheel sticks out farther and will rub on the zinger recoil, i tried to space it out and use it but for whatever reason it had too weak of spark to run, i ended up using all the zinger electronics, on the rh side of the clutch case you need to grind off a tab so the engine will fit in the zinger frame. You also need the zinger intake manifold, it is longer.Click image for larger version.
Name:	zinger engine.jpg
    current trikes:
    84 225dx with HID
    2 Speed tri Zinger
    I had:
    82 atc70
    Nov 2008
    Coon Rapids, MN
    956
    Thanks for all the good zinger info mattchow88
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    camy is offline New to the board Arm chair racerNew to the board
    Sep 2008
    Quebec, Canada
    63
    it would bark the tires on asphalt back in the day with a kid on it....lol.........
    Ho welll I need your receipe to do that! I have 2 towny and 3 tri-zinger now.... I have a kenny robert pipe to go on... a malossi kit... i need to get an intake setup looking forward to get this thing bark.....
    Tomy ATC- my mother gave it!!!
    1985 ATC 250SX
    1985 ATC 200X
    1985 ATC 200X
    1985 ATC 200X - Bought from Yamada. Resto mod project
    1985 ATC 70 - Full resto... girlfriend's bike
    1984 ATC 70 - In restoration Lifan 120cc in project
    1983 ATC 70 - Full OEM yard beater!!!!
    1983 ATC 70 - Sold to Yamada who sold it
    1979 ATC 70 - Sold to Yamada
    1973 ATC 70 - 125cc ripper to be bring back to stock
    1985 TRI-ZINGER
    1984 ALT50E
    1983 ALT50D
