Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: 2 speed tri zinger vid
    Fox Valley Wisconsin
    35
    Quote Originally Posted by fastatc70 View Post
    Wow that tri zinger brings back memories. What bike did you get 2 speed motor from? A friend of mine has my old zinger he wants to build it to keep up with my atc70.
    Its from a towny, good luck finding the engine or parts, they only made them one year and alot of the qt guys grab them up, I paid $200 for my blown up towny engine. Thats weird, I actually raced a stock atc70 with my original zinger engine in and we were dead even, He did have smaller shifter kart tires on it though!
    current trikes:
    84 225dx with HID
    2 Speed tri Zinger
    2 more tri zingers and 4 zinger
    I had:
    82 atc70
    80 tri moto yt125 with Dt175 topend
    35
    Good lookin rig, now if i can fit all 4 zingers in there?
    current trikes:
    84 225dx with HID
    2 Speed tri Zinger
    I had:
    82 atc70
    fastatc70 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Northbrookfield, Ma
    166
    Wow I have been doing this for a while and I have never heard of a towny. What year what is it?
    Trikes:
    1985 ATC 70 mod to 184cc
    1984 ATC70 mod to 124cc
    1983 ATC 70 Xmas restoration
    Quads:
    1986 TRX 250R
    2002 TRX 400EX
    2- LT80 for the kids
    1986 LT 50
    kzr800's Avatar
    kzr800 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2011
    USA
    167
    Very cool, I would like to hear more about the 2-speed mod. I have a Zinger I want to pimp out.
    2008 Arctic Cat - Z120
    2005 Kawasaki - KFX 700
    2005 Kawasaki - KFX 80
    2004 Arctic Cat - Firecat F-7 EFI Nightfire
    2001 Arctic Cat - ZR800
    1999 Arctic Cat - ZL 600 EFI
    1993 Arctic Cat - Thundercat 900
    1991 Arctic Cat - El' Tigre EXT 530 (2)
    1986 Arctic Cat - Kitty Cat
    1985 Honda - 250R ATC
    1985 Honda - ATC 70
    1985 Yamaha - YT60 Tri-Zinger
    1983 Yamaha - V-Max 540
    1981 Yamaha - SRV 540
    1981 Scorpion - Sidewinder 440
    1973 Arctic Cat - Kitty Cat
    35
    TOWNY 2 SPEED TO ZINGER MODS engine is from a 1982 yamaha towny MJ50. If you get a complete towny engine its a fairly easy swap, i always split the cases on my engines to inspect, all your out is the 2 intake gaskets, base gasket and maybe the side cover gasket, they use yamabond to seal the case halves. when they are apart i remove the kickstart and oil pump and related parts, I dissassemble the oil pump remove all parts and fill it in with JB weld to use it to plug the hole in the case. You can order the plug for a zinger case to block the kickstart hole. the flywheel and stator ARE DIFFERANT, the flywheel sticks out farther and will rub on the zinger recoil, i tried to space it out and use it but for whatever reason it had too weak of spark to run, i ended up using all the zinger electronics, on the rh side of the clutch case you need to grind off a tab so the engine will fit in the zinger frame. You also need the zinger intake manifold, it is longer.Click image for larger version.
Name:	zinger engine.jpg
    current trikes:
    84 225dx with HID
    2 Speed tri Zinger
    I had:
    82 atc70
    Nov 2008
    Coon Rapids, MN
    956
    Thanks for all the good zinger info mattchow88
    My feedback.
    My album
    camy is offline First Time Rider Arm chair racerNew to the board
    Sep 2008
    Quebec, Canada
    79
    it would bark the tires on asphalt back in the day with a kid on it....lol.........
    Ho welll I need your receipe to do that! I have 2 towny and 3 tri-zinger now.... I have a kenny robert pipe to go on... a malossi kit... i need to get an intake setup looking forward to get this thing bark.....
    Tomy ATC- my mother gave it!!!
    1985 ATC 250SX
    1985 ATC 200X
    1985 ATC 200X
    1985 ATC 200X - Bought from Yamada. Resto mod project
    1985 ATC 70 - Full resto... girlfriend's bike
    1984 ATC 70 - In restoration Lifan 120cc in project
    1983 ATC 70 - Full OEM yard beater!!!!
    1983 ATC 70 - Sold to Yamada who sold it
    1979 ATC 70 - Sold to Yamada
    1973 ATC 70 - 125cc ripper to be bring back to stock
    1985 TRI-ZINGER
    1984 ALT50E
    1983 ALT50D
