Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: Do you even run??
    Quote Originally Posted by kebby28:1210390
    I agree, but I have never found a gasket for the valve/cam cover on the 200 motors. It says in the manual to use gasket maker but warns of getting it in the oil port next to the backside of the cam. I was also confused about the little rubber plug next to the camshaft and couldn't find any info on it anywhere so I decided that was just where they had to drill to make the port and the plug has to be in. I was so confused because it almost looked like hardened gasket maker and it gave me that feeling of "oh, thats why the top end is smoked" but... that wasn't the case.
    I may be missing your point, but what does that have to do with using automotive oil in a trike?
    Feb 2013
    Shipshewana Indiana
    51
    Hondas never die!!!
    hondawasaki's Avatar
    hondawasaki is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Murray, UT
    319
    The cams are hardened, but only on the surface. Once the hardened surface is worn off, (usually due to the oil breaking down) the rest of the cam material goes very fast. We see it all the time in the auto industry. It is amazing that the engine still runs, but not surprising.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by Gator72007 View Post
    I have wondered this about our trikes but havent seen it mentioned here like in auto forums, i ran an additive (zinc) from comp cams in a old flat tappet cammed truck i had for these cam issues, seen lots of guys loose cams that didnt run it in autos.
    I have some of this zinc additive left, is it ok to run in trikes?
    wont harm the clutches?
    Hello Gator 72007
    Below are the answers to your questions plus some more detailed information I thought you might find interesting.
    xxxxx
    “I have wondered this about our trikes but havent seen it mentioned here like in auto forums,”
    Even after the automotive flat cam crisis of around 10 years ago which I was inadvertently involved in with Comp cam’s, it is still only known outside the professional automotive and oil mfg industry primarily by just SOME knowledgeable automotive hobbyists and 4 stroke motor cycle racers etc.
    xxxxx
    “i ran an additive (zinc) from comp cams in a old flat tappet cammed truck i had for these cam issues, seen lots of guys loose cams that didnt run it in autos.”
    Yes I explained the cause of this in my previous post as you have read.
    xxxxx
    “I have some of this zinc additive left, is it ok to run in trikes?”
    Not a simple question. It depends upon the additional additives in your particular brand of ZDDP and EXACTLY what the chemical components are of the oil you are mixing it with. I has been determined by Mobil 1 if I remember correctly that all grands of ZDDP do not mix with all types of oil well contrary to what many first believed. In general though it is pretty safe primarily in non synthetic motor oils for sure.
    xxxxx
    “won’t harm the clutches?”
    As you can see by the specs below, both Valvoline VR1 Automotive and VR1 Motorcycle oil’s have ZDDP in them, so according to them, no it won’t harm your clutch. You can call their hotline to have them explain anything you want about oil, it’s pretty cool. You will notice the zinc/phosphorous levels in the motorcycle oil are slightly lower than the levels in the automotive version, I do not know why. The levels shown below in the automotive version are purported to be from 2011. Valvoline claims this blend is obsolete and their new blend of it actually contains slightly less levels of zinc @ .13% and phosphorous @ .12%. I do not know why they did this either. Their VR1 Automotive “not street legal” oil is synthetic and currently has. 14% zinc and 13% phosphorous.
    xxxxx
    ADDITIONAL INFORMATION
    DOES MOTOR OIL BREAK DOWN? – The accurate question is yes but this is answer does not fully explain what really happens. Valvoline’s explanation as to why automotive engine oil breaks down is accurate but again incomplete. There are some articles by others that go further in explaining this break down process by saying that natural oil from the ground that is used in automotive oil actually never really breaks down unless it reaches a temperature that causes it to do so. They say this temperature is actually typically never reached in most automotive applications. It is the additives they add to the oil like the ZDDP and detergents etc that break down or wear out if you will and not the actual oil itself. This is EXACTLY the reason they can reclaim used automotive oil and resell it for automotive use. They basically clean it then re-infuse hydrogen back into it to make it suitable for use as a base for the production of automotive oil, pretty cool again.
    Valvoline can answer any questions you have regarding this topic also.
    Below is an excerpt from an article by Scientific American from an interview done with engineers Joseph Franceschi and James Condela of Universal Lubricants, which just completed a 45.4 million liter refinery in Wichita, Kans., to convert used oil into usable motor oil.
    “We clean that used oil by using pretty conventional refinery technologies. One of them is vacuum distillation, which dewaters the oil. Used motor oil comes with somewhere between 5 and 7 percent water in it. The first thing you have to do is get the water out of it.
    Then we do wiped-film evaporation. This essentially separates out all the contaminants and additives that are put into passenger car motor oils. Then after that, we go through a hydrotreating process that gets up to 700 degrees Fahrenheit and 1,100 [pounds per square inch]. That infuses hydrogen back into the hydrocarbon molecules and makes it a very high quality re-refined oil.
    If you're thinking of it in a very simple way, we're filtering the used oil with very sophisticated technologies and processes.”
    xxxxx
    CAN YOU RUN AUTOMOTIVE ENGINE OIL WITH LOW OR NON EXISTENT LEVELS OF ZDDP IN A WET CLUTCH MOTORCYCLE ENGINE WITHOUT CAUSING CLUTCH DAMAGE?
    EXCERPTS FROM AMSOIL WET CLUTCH TECHNICAL SERVICE BULLETIN PASTED BELOW SEE FULL BULLETIN FOR FURTHER INFORMATION
    “Improper driver operation: Motorcycle and manual ATV
    clutch operation requires human control which can impact
    performance and life of the clutch. Excess slippage as a result
    of continually riding the clutch or improper engagement
    can lead to excessive wear and reduced frictional plate life.
    It can also promote plate glazing resulting in even more slippage.
    11. Use of an incorrect fluid: As mentioned previously, not all
    lubricants are suitable for use in wet-clutch applications.
    Those containing materials such as friction modifiers or
    extreme-pressure additives can promote clutch slippage,
    eventually shortening the life of the clutch. Lubricants formulated
    specifically for wet-clutch applications provide varied
    performance. Using an oil that is more viscous (thicker)
    than recommended, for example, can result in higher operating
    temperatures and sluggish [sticking] plate release.”
    “Lubrication-related wet-clutch issues stem more from
    additive chemistry than the base oil used in the lubricant. Therefore,
    general statements suggesting synthetic oils somehow offer
    less compatibility are generalizations based on a flawed hypothesis.
    Keys to selecting the correct oil for use in wet-clutch applications
    include:
    1. Ensuring the oil meets the JASO and ISO frictional
    requirements set forth by the equipment manufacturer.
    2. Making sure the oil can provide high-temperature and oxidation
    stability.
    3. Checking that the oil offers shear stability and controls
    foaming.
    4. Using the oil with the correct viscosity (grade) recommended
    Use of the proper oil will ensure maximum clutch life and
    improved operation and performance.”
    http://www.amsoil.com/techservicesbu...quirements.pdf
    xxxxx
    IS ZDDP “SNAKE OIL” – Again I will not offer an opinion here but will simply relay a little info on the subject. It has been scientifically proven by hundreds of wear tests that not only the oil companies do but also independent unbiased agencies like the Automotive Society of Engineers and several other independent scientific testing labs that ZDDP does in the proper amounts does in fact significantly reduce wear on mechanical parts. I’ll try to find a couple articles regarding this and post them in a day or so. It’s actually easy to do on one’s own by simply entering “zddp camshaft” or “zddp test” into your computers search engine.
    This being said too much of a good thing is not such a good thing either as it has also been determined that levels of ZDDP above .14% can over the long term cause engine damage due mainly to the phosphorous however I don’t remember exactly what this long term is but the funny thing is that I think it was significantly longer than the test part lasted in the test using oil without zddp, lol. The fact that zddp does increase is is consistent a remember this. O
    GM BULLETIN – For those of you that have read the GM bulletin titled “debunking oil myths” I have also read it and for those in the know it is clearly riddled with incomplete statements [only partial selective information] regarding primarily ZDDP and Synthetic oil. There are many scientific test results that more completely explain the proven benefits and/or of these particular items. Once thoroughly informed it is clear that for some reason GM had some sort of agenda that as of yet is unknown to me.
    The fact that it conspicuously omits several documented facts such as the one I referred to in the “SNAKE OIL” section above seems to have disqualified it from being an article that would be considered “truly scientific” which are “supposed’ to be [complete” and unbiased], in many scientists eyes. Furthermore these glaring omissions automatically disqualify it from being eligible for publication in any “peer reviewed” scientific magazines.
    xxxxx
    CURRENT VALVOLINE CONVENTIONAL MOTOR OIL – As you can see by the spec sheet below Valvoline currently does have ZDDP in it however it is obviously in what is considered a significantly reduced amount when compared to their VR1 racing oil which actually has the same amount ZDDP they used to have in their standard non specialty oil prior to around 74. They recommend this oil for use in Roller Cam Catalytic Convertor motors only due to it’s reduced anti wear properties compared to their racing oils.
    If I remember correctly the level of ZDDP in this newest blend of oil is actually higher than it previously was. Unfortunately I no longer have access to those older spec sheets to evaluate the previous level for comparison. They can tell you for sure if you want to call.
    xxxxx
    CAN I USE STANDARD AUTOMOTIVE OIL IN MY NON ROLLER CAM MOTOR – Absolutely, many people have without what they might realize are the adverse effects of doing so such as premature engine wear etc.
    The problem for me is that I personally think that, that is not the best question to ask but instead think the question [which most people I personally know], ask anyway is, “Which oil will is the best to use in my particular engine and why?”
    Just because one has run a standard automotive oil with either low or non existent levels of ZDDP with “no” problems is in no way scientific proof that it is the best oil to use in a non roller wet clutch motorcycle. It’s simply proof that one has done this without “obvious” problems and nothing more.
    Simply to assume that because one has not experienced any problems doing this over the long haul in no way proves that if in fact one had used an oil with the oil companies recommended levels of ZDDP for non roller motors that their motor would not have less internal wear due to those levels of ZDDP that have been scientifically proven to reduce engine wear, subsequently significantly increasing an engines life.
    xxxxx
    Sorry the following didn't cooy properly but one can still see the zinc and phosphorous levels in each.
    VALVOLNE VR1 NON SYNTHETIC
    MOTORCYCLE OIL 20-40 20-50
    Vis @ 100°C (cSt) 15.2 20.0
    Vis @ 40°C (cSt) 104.1 169.4
    Viscosity Index 155 124
    Spec Gravity @ 60°F 0.8732 0.8848
    Density (lbs/gal) 7.28 7.38
    Total Base No. 8 8
    Flash COC (°C) 216 230
    Pour Point (°C) max -30 -24
    CCS cP (°C) 6200(-250C) 8400(-150C)
    MRV TP-1 cP (°C) 38000(-300C) 28000(-200C)
    Noack % off @ 250°C 15.0 7.3
    Sulfated Ash, wt.% 0.80 0.80
    Zinc/Phosphorus, wt.% 0.112/0.103 0.112/0.103
    Calcium/Sodium, wt.% 0.182/0.052 0.182/0.52
    VALVOLINE VR1 NON SYNTHETIC AUTOMOTIVE OIL
    Test 10W-30 20W-50
    Vis @ 100°C (cSt) 11.5 20.5
    Vis @ 40°C (cSt) 77.0 181.8
    Viscosity Index 143 132
    Spec Gravity @ 60°F 0.8722 0.888
    Density (lbs/gal) 7.27 7.39
    Total Base No. 8.5 8.5
    Flash COC (°C) 212 248
    Pour Point (°C) -33 -24
    CCS cP (°C) 6200(-25C) 8000(-15C)
    MRV TP-1 cP (°C) 20,000(-30C) 27,000(-20C)
    Noack % off @ 250C <15 <15
    Sulfated Ash 1 1
    Zinc/Phosphorus 0.14/0.13 0.14/0.13
    Calcium 0.210 0.210
    Sodium 0.049 0.049
    CURRENT VALVOLINE CONVENTIAL MOTOR OIL FOR NEW CARS
    Approvals/Performance Levels Viscosity Grade/Other
    API SN/SM SAE 5W-20 SAE 5W-30 SAE 10W-30
    ILSAC GF-5 & GF-4 SAE 5W-20 SAE 5W-30 SAE 10W-30
    Resource Conserving SAE 5W-20 SAE 5W-30 SAE 10W-30
    FORD WSS-M2C946-A - - - - - - - - SAE 5W-30 - - - - - - - -
    FORD WSS-M2C945-A SAE 5W-20 - - - - - - - - - - - - - - - -
    GM 6094M ** - - - - - - - - SAE 5W-30 SAE 10W-30
    Chrysler MS-6395 SAE 5W-20 SAE 5W-30 SAE 10W-30
    Honda Feb. 2001 Spec. SAE 5W-20 - - - - - - - - - - - - - - - -
    Test SAE 5W-20 SAE 5W-30 SAE 10W-30
    Vis @ 100°C (cSt) 8.5 11.0 10.5
    Vis @ 40°C (cSt) 50.0 63.0 69.7
    Viscosity Index 146 168 137
    Spec Gravity @ 60°F 0.861 0.861 0.871
    Density (lbs/gal) 7.18 7.18 7.26
    Total Base No. 7.3 7.3 7.3
    Flash COC (°C) 220 220 216
    Pour Point (°C) max -42 -42 -36
    CCS cP (°C) 6100(-30°C) 6100(-30°C) 5900(-25°C)
    MRV TP-1 cP (°C) 20,000(-35°C) 25,000(-35°C) 20,000(-30°C)
    Noack % off @ 250°C <14.5 <14.5 <14.5
    Sulfated Ash 0.80 0.80 0.80
    Zinc/Phosphorus 0.083/0.076 0.083/0.076 0.083/0.076
    Calcium/Sodium 0.167/0.049 0.167/0.049 0.167/0.049
    Gator72007 hope this info helps.
    Jan 2013
    minnesota
    5,911
    Sorry post correction. The second Valvoline oil listed is actually their Synthetic VR1 "not for street use" oil, not "non synthetic" as posted. I have no edit button on my screen for the site.
    Jan 2013
    minnesota
    5,911
    Hello Gator72007
    My previous post has a couple typos I hadn’t noticed when I posted it however I have no ability to edit my posts so I can’t correct it. Sorry.
    I also noticed I missed a category so I will include it below.
    CAN OLD OIL CAUSE ENGINE DAMAGE – Yes, in general it certainly can since as mentioned previously the additives in the oil break down/wear out etc reducing it’s friction reducing properties and also by allowing moisture to accumulate in it etc. It also gets contaminated from material worn off of internal parts and from contaminates created by the combustion process etc.
    HOW OFTEN SHOULD I CHANGE MY OIL – In the case of an ATV, the safest thing to do is simply change it every year no matter how much you ride it. This gets rid of any moisture that might have accumulated in it especially in wet, humid or cold climates etc. This includes things like riding it through streams mud bogs etc.
