Results 1 to 15 of 21
Thread: US90 points/condenser upgrade to 110 CDI - anyone try it?
    Jun 2003
    South of Rochester, NY
    3,471
    Have a old school Joker frame and a US90 chromed carrier/sprocket/brake assembly laying around here for years. Decided I will finally put it together. I have another US90 motor that 'lost spark'.... is there any way to upgrade the ignition to a later model 110 with the CDI???
    Thanks
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Nov 2007
    ulysses pa
    1,231
    the 90's used an inner rotor and the cdi 110's used an outer. your problem is gonna be at the crankshaft trying to get the late model stuff to fit. i think a fella on this board did this conversion but it sounded like alot of work.
    tblumer's Avatar
    tblumer is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    Liverpool NY
    225
    A guy over on the CT90 yahoo group converted a points motor on his CT90 to cdi using ATC110 parts. I think it's doable but won't be just a parts swap.
    84 ATC 70 w/88 (for the kids)
    85 Yamaha YTM200 (Protek suspension / Tecate forks)
    74 Joker frame ATC 90 w/ 110 cdi
    71 Honda Z50AK1 Mini Trail w/117cc stroker
    CRF50 stunter w/117cc stroker
    08 Yamaha WR250X
    My feedback:
    http://www.3wheelerworld.com/showthr...89#post1080789
    tblumer's Avatar
    Nov 2009
    Liverpool NY
    225
    I uploaded a pdf of Scott Kirns' cdi conversion
    https://www.box.com/s/sda2d235kxsa4xnpm6q5
    08 Yamaha WR250X
    My feedback:
    Jun 2003
    3,471
    Quote Originally Posted by tblumer View Post
    Thanks man... a lot to digest there, but looks like a lot of it will switch over. Thank again...
    6,813
    Points
    I have this atc90/110 points eliminator setup , kinda neat piece of old school history . Came in a parts lot that I picked up and I haven't tried it yet .
    Attached Thumbnails Attached Thumbnails pointseliminator.JPG   pointseliminatorr.JPG   pointseliminatorrr.JPG
    Jun 2003
    3,471
    That is pretty neat!
    PS - Joker frame on ebay. Search Honda Joker Frame
    6,813
    Yeah I seen that frame for sale . I have a pile of aftermarket frames as well ... you need one LOL ?????
    Quote Originally Posted by 350x'inNY View Post
    tblumer's Avatar
    Nov 2009
    Liverpool NY
    225
    Same guy has a Nicholson up too, think he had a Pauter for sale a while back.
    08 Yamaha WR250X
    My feedback:
    Jun 2003
    3,471
    Since I got a couple of you Joker frame guys on the line.... will any US90 - ATC90 - ATC110/125 set of forks mount to the steering stem? I am hoping to use a US90 set of forks and such, as the rear carrier/axle that was with the frame was a US90 setup.
    Bruce
    tblumer's Avatar
    Nov 2009
    Liverpool NY
    225
    They should, i just popped a set of all balls taper bearings and 90 forks on mine. With some slight trimming on the forks you can pop on 185/200s forks too.
    08 Yamaha WR250X
    My feedback:
    Feb 2013
    chicago il
    505
    all the 90/110/125 frames have same neck so any frame will accept any triple tree. I have 200 s springer forks on my 125m's .you have to cut off the steering stop on the frame but they go right on.
    I was going to do same thing with switching a 90 motor to cdi stuff but the crankshafts are different where the flywheel mounts. and as someone said one used inner rotor and other outer rotor so the case is different as well. and you have to switch those parts because points bikes are 6 volt and cdi is 12 volt. buy a cdi motor.
    Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
    Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
    Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
    KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
    tblumer's Avatar
    Nov 2009
    Liverpool NY
    225
    Quote Originally Posted by trike savior View Post
    I assume you didn't look at the pdf I posted. Alternator appears same as atc90.
    08 Yamaha WR250X
    My feedback:
    Jun 2003
    3,471
    I ended up buying a 110 CDI motor with complete wiring harness and new carb on CL last night. I guess it's going to be a US90-110 mutt with each generation of 90/110s being represented.
    Feb 2013
    chicago il
    505
    the way I was talking about was using all the parts from a cdi motor on a points motor but for all the work it takes it is not worth it. my info comes from personally having these two motors side by side on the bench. the points bike and cdi bike have big differences. not in the parts on the cam but the parts on the crank. and I know one is 6 and one 12 because they use different volt light bulbs. but that is just the lighting side of the generator. the ignition side of the generator is different and cdi uses a lot more voltage than points. that is why the pdf explains that he had to rewire the generator. it looks like he used the original generator parts but rewound it with the proper wire to get the voltage needed to run cdi. pdf says 25 volts which sounds about right.
    if you have the expertise to rewind the generator coils like in the pdf then do it but doing that is something that is easy to get things wrong and have it not work. if you can do that you will have power to run cdi and still use 6 volt lighting system
