Results 1 to 7 of 7
Thread: 85 kxt250 leak mystery
    newport news. va
    23
    So I just noticed that my kxt250 slowly leaks anti freeze from the head gasket area. I changed the gasket, torqued to specs and still leaks. Its actually more like sweeting through the gasket it seems. could this possibly be because of the cheaper after market gasket? I also just had to top end machined and new piston and rings installed. Has anyone seen this before?
    Arizona
    843
    Hmmm...never seen that on mine. You say you got the "top end machined" but does that mean the head AND the top of the cylinder? If either one is warped or gouged it could be the source of your problem. Or, perhaps a bad gasket even though it is new. There aren't too many possibilities.
    I owned Tecates for years. I never use aftermarket head gaskets, only OEM. I've seen them seep like that more than once. Eventually all of mine stopped seeping. Give it some time and keep your eyes on it. I bet it will stop.
    newport news. va
    23
    Thanks fabiodriven, that puts me at ease a bit. I only have about 10hrs or less on the new top end. I just keep an eye on it for now. I did just purchase an OEM gasket so that will go on if the seeping does stop soon.
    hondawasaki's Avatar
    hondawasaki is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Murray, UT
    319
    I agree, the cooling surfaces are sealed with a fiber material gasket, most often they will swell to seal. If it does not stop, take it apart, and check the flatness of both surfaces.
    Thank god we solved that mistery
    Oh boy, where will the next generation lead us........................
    newport news. va
    23
    Yeah, sorry for the spelling. lack of sleep and 2 young kids sick with their heads in the toilet doesn't leave much time to turn the brain on all the way.
    Thanks again for the help. Both surfaces were machined so I would think they would be perfectly flat.
