Results 1 to 13 of 13
Thread: 1984 250r ATC shock help!!
    Mar 2013
    Wilmington N.C.
    15
    The guy who owned this three wheeler before me extended the Swing arm and in the mean time cut off the shock brackets. I was wondering if anyone could give me pics on how this all goes back together and where ish I should weld new brackets. Thank you for any pics or guidance!
    Dec 2012
    nl/canada
    62
    http://cgi.ebay.com/ebaymotors/1983-...7fabc01f#v4-45
    thats a link to one for sale, with pics, its an 83, but shouldnt be any difference
    Jan 2013
    minnesota
    5,911
    Hello
    Do you have photos of your stuff you can post a link to. Rcurtis photos are very and helpful but my guess is that you might have a little bigger problem. We'll hope not.
    That's a nice bike seems lik a steal for a clean classic like that but it hasn't hit the reserve yet. Probably wants $4k or more.
    Sep 2011
    Ocean Beach, CA
    1,333
    Quote Originally Posted by rcurtis16 View Post
    There IS a difference between 83 and 84 swingarms
    Mar 2013
    Wilmington N.C.
    15
    The pic from eBay helped a whole lot! There is a swing arm cushion and a dog bone with mine. Are these important parts because most of the pics I can find don't seem to have them hooked up and if that is the case then I might have this thing figured out. I will have pics to come soon. Thank y'all!
    Carthage NY 250r rules
    2,355
    There is alot of difference between 83 and 84 250r suspension and rear shock,linkage,dogbone,swingarm and rear shock/motor mount.I just changed my 83 300r rear over to the 84.I had to change everything except pivot bolt.
    250r rules
    Mar 2013
    Wilmington N.C.
    15
    I am sorry about the bump, but I still need help! Thank you
    2,355
    Couple pics.This is 84 style.Click image for larger version.
ID:	166429 Click image for larger version.
    250r rules
    Mar 2013
    Wilmington N.C.
    15
    THANK YOU! That is awesome! One last thing I am confused about is the "cushion arm" coming off the lower part of the dram, how does that mount? If you tell me that it's not important, then bye-bye it goes. Hopefully that is the answer because it doesn't seem to "fit" anywhere. Thank you!
    Mar 2013
    Wilmington N.C.
    15
    *frame* I meant frame
    2,355
    The lower shock mount,lower dogbone and linkage all bolt together with one long bolt. Click image for larger version.
    250r rules
    2,355
    Can you post a pic or two of what your working on.
    250r rules
    Mar 2013
    Wilmington N.C.
    15
    That is absolutely perfect! Thank you! I will post pics soon, I am new to the forum and still figuring things out. The guy who had it before me did a horrible swing arm extension! Luckily it is all fixable with a ton of grinding and a little welding. Thank you for posting the pics for me! I will get the pics up soon.
