200x extended axle
i have a old extended 6+ axle... i need o find out where to get parts for it...i need a new lock nut and retainer ring...ita either a old durablue or finishline..i really cant tell....other than that its mint..
post pics. as far as i know all 200x axles used the 2 oem locking nuts.
this is a aftermarket axle,,not a stock one.... it has a ring that sits in a grove in the axle,,and another retainer sits against that and a big nut that tightens against that..
sounds like a durablue. they dont make them axles no more. i run a 82 250r durablue in mine with a posi lock. maybe that would be the same but with out pics you dead in the water for other memembers to compair with.
i will try to post a pic later if i can..thanks for the help
Pics of the axle and the nut that I need
honestly looks just like my 82 250r durablue. sprocket set up is just like mine was before we modified it. axle nut its the same...im sure finish line axle did not come like that at all because thats not the stock 200x sprocket set up...its 250R 1982.
see my thread in HRE 200x if it is like i think it is you can buy a new posi lock in ebay for about $90.
thats good news..thanks... on yours did that inner ring have teeth all the way around ? mine only had one,,lol,,, or is it missing all the rest...in the middle pic shows where the last one was... i was able to get this real cheep...and the swingarm too.. i think its a dico 2+.. again not sure.. i havent seen these in years...
I'm running an extended durablue axle on the powroll 200x i Built for the yard....If you need any pics of the setup let me know ...
Here ya go just incase ...
My set up is the same as Gates...just modified. dura blue sells parts for these axles, they say in their site to use 82 R axle in a 1st gen 200x. which is what boy yall got it looks. heres mine.
http://www.ebay.com/itm/SPROCKET-HUB...r#ht_161wt_782 if they sell spares they will sell the posi lock and C lips...just call durablue. but im certain you axle is not 200x. its got R writting all over it.
Does anyone have a source for the sprocket bolts for that axle by chance?
for what axle? i run all trx quad stuff in my 82 250R conversion
//ArrowChat Integreation Code
