Thread: Will an '86 200X ON/OFF switch fit an '85/86 350X?
    May 2003
    Houston, Texas
    2,409
    Anyone know?
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    Are you looking to use just the switch itself, or the whole housing/ light switch, also?
    The Goal... All I Need Is The Time...
    Terryville,CT
    1,616
    from what i can see in the manual the 85 has 6 individual connectors, the 86 has two multi prong connnectors so you can probably modify it with the two manuals to make it work if you wanna go that route
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    NEPA
    7,051
    Never done it ,but some simple wiring would surely get it on there. I know you won't go for this because of the starter button. But last I knew TRX 250EX switches were like $28. New from Honda.
    There is a kit you can buy (someone posted it up), which allows you to change ends with covered bullet connectors and so forth.
    All you need is a wiring diagram and that kit if you want it to look professional.
    May 2003
    Houston, Texas
    2,409
    Very good to know....thank you!
    Dirtbikes:
    1988 Yamaha DT
