200ES Front Shock Options
Anyone know of a source for replacement springs and dampeners for the front forks of a 1984 200ES? Anyone done anything with newer components by replacing or modifying the stock front suspension? WHat options are out there to help the tired front end?
A good used set if you can find one...most of the plastic guides are still available new from Honda if you'd like to rebuild, otherwise a 200m front-end is nice conversion, but you'll need to find the whole front end (triples, shocks, fender, axle/brake, headlight mounts) and you'll lose your front rack, unless you can find one for a 200m. The 200m is a wet shock system which is way better, unlike the dry setup on your BR.
//ArrowChat Integreation Code
