"comes up and brings up solid" confuses me a bit, but I assume you are saying the there is contact between the piston and valve that is stopping the engine.
Did you remove your piston to install the rings or just slip them on?
If you removed it and while reinstalling it you rotated it 180 then there might be your issue..since the piston has a indent for the valves to clear the piston on the up stroke. If you got it backwards you have the valve hitting the piston head on the opposite side of the piston..
Since the two valves are not the same size (generally the intake is bigger) then also the indent on the piston top is different.
It's likely your intake valve that is hitting.
I assume you used the manual while reinstalling your chain to get be sure where your marks should be?
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
