Honda 350x Rod Bearing
Hello all been around the site for awhile now but this is my first post.
I am rebuilding my motor and I plan to replace just about everything I can. I have found all the bearings along with a new rod and crank pin.
However I have run into one issue. I am using all OEM parts and I found there to be 3 rod bearings listed on the Parts Fiche. Can someone tell me which one is to be used with a new crank pin and a new OEM Rod. The part numbers are listed below.
13211-HA5-003 BEARING, CONN ROD 1 14.40
13212-HA5-003 BEARING, CONN ROD 1 18.89
13213-HA5-003 BEARING, CONN ROD 1 14.91
Any help you can give me on this is greatly appreciated. Also thanks for all the help that has been given already. I have used this wealth of info to completely rebuild this bike. This is the last thing to do.
Hello
You need to measure the id of the rod. the 14.4, 14.91 and 18.89 numbers should be the id of the rod in Millimeters. Buy the corresponding bearing.
Hope this info helps.
//ArrowChat Integreation Code
