Thread: 1984 honda 200es sub transmission service
    Mar 2012
    Jamesport
    40
    How do I change the oil in the sub transmission? what oil do I use?
    1970 ATC US90
    1984 ATC 200X
    1985 ATC Big Red 250ES
    1985 ATC 70 x2
    1984 YTM 225DX
    1985 KLT 185
    2007 CRF 450R
    1995 Kawasaki Bayou 300 4x4
    Dec 2007
    Quebec,Canada
    1,014
    If I'm correct,no service needed,the oil pump from the motor push oil in the subtrans
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Mar 2012
    Jamesport
    40
    is there an adjustment on there? it sifts hard.
    1970 ATC US90
    1984 ATC 200X
    1985 ATC 70 x2
    1984 YTM 225DX
    1985 KLT 185
    2007 CRF 450R
    Howdy's Avatar
    Celina, Ohio
    10,079
    No adjustments on it. You might need to take it apart clean and re-assemble it. I would spray some lube around the arm and let it sit overnight to see if it helps. Then if it don't then take it apart and clean.
    Howdy
    kebby28's Avatar
    Nov 2012
    Antrim, NH
    435
    Mine likes me to put it in 1st as I'm sliding the lever into low or reverse then it gently syncs right in.
    The shift fork drum may be gummed up...
    Make sure you order a new gasket if you're going to pull it apart. And have a diagram handy for putting it back together because some parts may fall and you'll need to know where they go.
    MN
    3,263
    My 200ES does the same thing, won't always shift in neutral, but put it in first gear and the sub trans shifts just fine.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
