My 84 200es slams into gear when I shift it, is there an adjustment?
1970 ATC US90
1984 ATC 200X
1985 ATC Big Red 250ES
1985 ATC 70 x2
1984 YTM 225DX
1985 KLT 185
2007 CRF 450R
1995 Kawasaki Bayou 300 4x4
There is a clutch adjustment in the manual, also consider checking your idle speed..it may be too high!
Both will cause it to clunk.
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
I second that, adjust the clutch and the idle... These are a semi-auto trans so they engage with rpm, think centrifugal clutch like on a snowmobile for a comparison, if your idle is too high its right on the verge of gripping and when you tap it in gear she clunks hard. When its all adjusted right you can have it idling and tap it into first gear and it won't even clunk or move for that that matter until you get on the gas.
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
