Results 1 to 8 of 8
Thread: 1985 200x Kick Start Return Spring - Not Returning After Rebuild
    Jan 2013
    Wisconsin
    4
    I am a Wisconsin rookie trying to part two motors into one and have a good running machine. And using a manual...
    Got the engine and tranny back together, tranny shifted by hand and made sure my return spring is in good condition. However, got the motor ready to go back in and tested the kick start. It kicks over but the lever doesn't return at all. Can anyone tell me if the spring has to be pre-wound from the engine running? I am hoping this occurs after the engine runs for the first time.
    Any ideas would be great.
    WI Rook
    6,808
    The main kicker spring is pre-wound about a half turn also its very important to line ALL the punch marks up . The outer kicker gears if the correct gasket isn't used it will bind as well .
    Always test the kicker tension before you install the outer cases for engagement and ratchet function .
    Jan 2013
    Wisconsin
    4
    Thanks for the intel on the spring, I will double check all the punch marks on the outer kicker gears (sounds like I missed one).
    My worry was having to dis-assemble the main cases to get back to the return spring.
    Another thought was on the latching of the return spring. From my memory, I remember it latched over the inside of the casing that splits the tranny side.
    Ever here of the latch following off of the casing?
    6,808
    Yes one side of the spring goes in the cavity of the case and the other on the bolt . all those gears have punch marks as well and if their off it wont have the correct spring tension .
    Quote Originally Posted by 200xcheezmun View Post
    Mar 2013
    Minnesota
    441
    Each gear should be lined up with each punchmark. Like on the Shaft that the gear's go on there will be a punchmark and then on the gear itself there will also be punchmarks. Make sure that there ALL lined up.
    ~~ATC's Currently Owned~~
    1983 Honda 200x - Main ATC
    1985 Honda 200x - Parts Bike
    ~~ATC's Previously Owned~~
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1983 Kawasaki klt 200a
    1986 Honda 200s
    ~~Other Toys Owned~~
    2012 Pro R 800
    1993 Polaris Indy 500
    2004 Yamaha 125
    1990 Thunder Kart - 250CC
    2001 Yamaha Blaster - 240kit, aftermarket exhaust, power reeds
    Broken Arrow, Oklahoma / SouthEast Texas
    60
    I had a 1985 200x kickstart that wouldn't return and turns out the shaft was very slightly bent. Might not be the problem if yours worked before, but could be worth checking.
    Dec 2014
    Southern California
    23
    I'm having this same issue.. I've posted (I'm sure in the wrong area of the site).. Anyway, going to continue working on it, until I can get it to return like it should.. I attacked the kicker side of the case.. Only to find , that the spring can not be accessed on that side.. I'll replace the clutch while I'm there.. My return spring is definitely broken, or has slipped off it's designated place.. One end of it, is just hanging.. Any help would be appreciated.. One member stated "good luck" not sure what he meant by that ?? Was he being an ass, or is it truly an insanely difficult job?
    1985 Honda ATC 200X
    1986 Suzuki SP 125
    1996 Yamaha Banshee
    2001 Suzuki LT 80
    2004 Xtreme 107 pit bike
    2005 Suzuki RMZ 450
    2006 Honda CRF 50
    2014 Harley Davidson Street Glide 1690
    Pacific NW
    4,255
    Quote Originally Posted by Vdubin64 View Post
    I didn't realize that.
    I'd take the kicker cover off too.
    Interesting no mention of that.
    Most manual don't address specific fixes but general assembly
    and disassembly.
    Seacrh key for "kick start' should get you every thread written.
    as far as 'good luck'? comment.
    the moderators do not tolerate anything inflammatory.
    This site is for hard working folks looking for answers and quite honestly,
    some folks on here trust their lives to these machines.
    I know we certainly do during fire season so very little time
    for shenanigans.
    That's what the open forum is for, or 'this n that' , if appropriate.
    I'll wish you luck too because I know how frustrating things can get.
    Turn off the phone, put the cat and dog away, nice clean work area with good lighting and 1/2 the battle is getting the sequence.
    I usually read everything I can get my hands on, even if not specific to my machine, and as always, reverse thread stuff, if applicable, is not always clear.
    IS this a 200x problem?
