Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: Is tire slime really corrosive?
    9,019
    Quote Originally Posted by deathman53 View Post
    slime works great, yes it can be a mess. I have tubless dirtbike tires, I changed a tire and found a surprise, 2 small nails in the tire, didn't even know they were there.
    I run TuBliss on my dirt bike as well, but the Slime has made a mess of my rims AND my TuBliss system has degraded to the point of junk. They leak a lot now, so I had to replace both sets. Even the aluminium bead lock is corroded! Im putting the new ones on with dish soap as lube and carrying a can of tire seal in my bag, but if I have to use it I will wash it out theday after. No more Slime for me, even if the TuBliss guys do recommend it.
    NEPA
    7,051
    I am honestly blown away at this thread!!! I have used Slime and Tucker Rocky's Quad boss sealant,which is the same ,except it is blue instead of neon green. I will admit to dismounting only a few with it in,but they were simply that, Slimy. Washed up perfect with water and soap. I think MAYBE the rims were rusted out Before they slimed them. But there are way too many of you saying the same thing. I guess it's corrosive ??? . I honestly thought it was water based, fairly safe stuff. At any rate. The stuff works like nobodies business around my parts, And yes,,it IS a fixed for life deal. Put it in for a hole,,run the thing through a thorn apple bush with 30 punctures. They are ALL sealed and that tire will not go flat. Again,that is in my area where the temperature fluctuates 35-40 degrees somedays. And yes,,the correct way to repair a tire is to pull it down and Patch it. But this stuff has been a lifesaver for me and many customers. I am anxiously awaiting seeing my first " rotted/weakened aluminum rim"
    9,019
    Did you see my earlier link to the Slime website? Even they say it will corrode rims and don't recommend leaving it in.
    NEPA
    7,051
    Yes boss I did ! Lol,,,jka... That's why I Said I was so surprised. I have had 25 years of absolutely awesome experience with their product. I just can't believe it "eats" anything. But it obviously does Great thread!
    9,019
    I wonder if electrolysis and reactions between dissimilar metals in the wet environment of a Slime filled rim can be exacerbating some of the symptoms guys are mentioning on their rims? You know, like you see on boat engine skegs and props.
    Rittman, Ohio
    6,276
    I don't use it as a preventative, but it works great for sealing stubborn issues with tubeless such as bead leaks. You have to take the wheel off, and flip it over and over in such a fashion as to get it into the bed for it to work though. It will never find its way there under regular riding. Its also great fro sealing up plugs when you are in the field and find out your tube of vulcanizing cement has dried out.
    Its about as corrosive as water. Yes, steel rims with exposed bare metal will rust. Its never affected an aluminum rim for me. It can be a mess to clean up once it starts drying in there, but I've found that most solvents or gasoline will cut right through it, and you can clean it off aluminum rims with ease. If its still wet, it washes out with water. Other than the psychological impact of "knowing its in there", there is little need to clean it out, for the sake of cleaning it out. I cleaned up my old rims to sell them.
    It will dry out over time, and may end up as a bunch of little balls rolling around in your tire. Other than picking up my track Turf Tamers and hearing a couple rolling in one of them, I don't feel the need to break it off the bead to remove them, especially when the bead was successfully sealed with it a dozen years ago.
    I'm not sure by whom it was ordained that a patch is the only proper method of fixing a puncture. I do know that if I drive two hours to my riding spot, and puncture a tire, I'll be riding again in about 5 minutes while you are packing up your truck and heading home to find a tire machine. Good quality plugs properly installed can fix some huge punctures that patches will not, and they will work on sidewall puctures where patches will not. Get the professional automotive kind like the tool truck guys sell to garages, and not the retail kits. Patches are more reliable on the flat part of the tire if you want to give up your riding weekend to go home and install it.
    I love Tire Slime, and always keep some on hand, and have used it for many years. The only downside other than the mess when you eventually take the tire off is that it can kill a tire guage.
    Slime should not be confused with aerosol cans of Fix a Flat or similar products which are only good for emergency inflations, and rarely actually seal a leak.
    Mar 2005
    overton, PA
    5,257
    i ahve used slime on almost everythign i have ever owned with a slow leak, and tryign to plug a tire with slime in it alreaqdy can be a pain but not impossible. and when i dismount tires i usualy paint the insides of the rim with cheap spray paint to help work liek bead glue or bead sealer so thats probably why i haver had issues with corosion on steel rims.
    Apr 2013
    VT
    147
    Has anyone used or heard anything good or bad about High Lifter Pro Series Tire Sealant?
    1986 ATC250R
    1986 ATC200X
    1985 ATC200X
    MN
    3,263
    I cant find the pics of the damaged trike wheels but i was talking to a buddy of mine and said he knows a guy with slime damaged wheels...
    Here is the story, they are off his dune buggy i guess, in the first pic you can see the little balls of dried up tire slime from being in there a while. In the second pic you can see that after the little balls were cleaned off you can see pitted spots where every little slime ball was! Now this damage happened after a small amount was put into the tire to fix a leak, and some time passed, the actual time frame that passed he wasnt sure, maybe a year, but it did eat into the aluminum pretty good.
Name:	slime rim damage 001.jpg
ID:	174257Click image for larger version.
Name:	slime rim damage 007.jpg
    I will agree that a wheel that is already prone to damage, bare metal for a steel wheel, is probably going to be more prone to damage vs a nice painted one, but it will eat through the paint too eventually i am betting!
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    4x4van's Avatar
    4x4van is offline At The Back Of The Pack Arm chair racerFirst time rider
    SoCal
    160
    Wow, this website is really acting up; I can't post on a thread unless I "refresh", which then logs me out and I have to re-login. I can't edit one of my posts at all because it says I have no permission to and must refresh, which then logs me out. But then I'm back to where I started and still can't edit.
    Those pics are just weird...why would the slime dry up into balls "stuck to those specific spots" on the rim, unless they were there sealing up pinhole leaks that already existed? Once slime dries, the little balls roll around loose in the tire. I've used slime for years, for slow leaks, bead leaks, punctures, carcass seapage leaks (from older "over-buffed" skat trak tires), and have never had a problem with corrosion in my aluminum rims. Again, there's something that just isn't right about those pics. With the rotational forces of a spinning tire, and even with a stationary tire, there is no reason for slime to collect in little spots/balls like that on the inside of the rim, unless there was already pinhole leaks there. Something just doesn't add up.
    Those who can ride, ride...those who can't, drive.
    Husky250 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2010
    NE Ohio
    264
    My .02... I use slime on all my tubed tires but for some reason not on my tubeless. I have a buddy that puts a few balls from walmarket inside his tires in case of flats. Cheap and have personally seen it get him home (without trashing a rim.
    ScreaminRed's Avatar
    ScreaminRed is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2013
    NC USA
    391
    I have slime in all 3 of my big reds tires, only b/c they all had leaks and are 20+ years old. The only reason i did this is b/c i'm cheap and i wanted to get my use out of the tires b/c they have so much tread left. It sat in my Dad's shed for years, he didnt ride it much, but kept it running all that time. Once i brought it down here with me, i'm using it around the house hauling stuff. It's been a huge help! So far the slime is holding great, as for the rims on the inside...i'll know when i need to get new tires, i guess. So, maybe it will rust my steel wheels, idk. But, i'm not to worried about it at this point. If i need to get new wheels for it, I will.
    '83 Big Red
    '85 350X
    '86 350X
    '06 CBR1000
    '08 Road King
    '11 Electra glide Ultra Classic
    My feedback thread: http://www.3wheelerworld.com/showthr...or-ScreaminRed
    May 2011
    The Granite State
    914
    http://www.slime.com/category/faqs/
    •Can I use Slime Tube Sealant in a Tubeless Tire?
    No. This formula does not contain the rust and corrosion inhibitors necessary to protect a wheel. We do not recommend or guarantee performance of the product in this application
    They sell Slime for tube and tubeless tires, 2 different products ... I've used the tubeless Slime product a bunch and love it...cant say about corrosion though
    "•What is the difference between Slime for ATV’s and Slime for Autos?
    There are 2 varieties of Slime sealant; one is specifically for tires with inner tubes and one is for the tires. Auto and ATV tires generally do not contain inner tubes. For these applications, we recommend our tire sealant formula. If your vehicle comes equipped with a tire pressure monitoring system (TPMS), we recommend that you use our yellow label TPMS Safe Formula. This formula is specially formulated not to clog or harm TPMS devices."
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    86 350x : 84 250r X2
    85 350x X2 : 84 200es X3
    83 200e : 78 ATC90
    Mar 2013
    Minnesota
    441
    It's a 50 50 to be honest sometimes it works sometimes it doesn't depends on the leak
    ~~ATC's Currently Owned~~
    1983 Honda 200x - Main ATC
    1985 Honda 200x - Parts Bike
    ~~ATC's Previously Owned~~
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1983 Kawasaki klt 200a
    1986 Honda 200s
    ~~Other Toys Owned~~
    2012 Pro R 800
    1993 Polaris Indy 500
    2004 Yamaha 125
    1990 Thunder Kart - 250CC
    2001 Yamaha Blaster - 240kit, aftermarket exhaust, power reeds
  15. #30
    Mar 2007
    Texas
    5,045
    slime is a love-hate relationship. i run it on all my trail bikes. where we live in texas ther are tons of bull nettle with long enough thorns to puncture any tire. so we run it to keep from having to constantly fix flats. but also we do not run nice wheels ont he trail bieks either, we run cheapo crappy steel stuff. so it doen't matter if by the time the tire is bad we have to repalce both.
    i think slime is perfect for certain situtations and conditions but again i use it as a tool not as a oh, slap it in everything type of stuff. i know there's a real big chance when tires is bad i have to repalce tire and wheel both. and i am ok with that.
    it is corrosive and it will damage the wheel over long times. such as my useage, but again you need to determine your use. will not fix a big gouge or anythign larger than the size of a pencil hole, (not even that big)
    ________________
    https://www.mikesatvfix.com
